    PDP XBOX 360 Controller not recognized
    GamePad/GPIO/USB encoder
    pdp xbox 360 recognized
    • Alexandre Meylan
      Alexandre Meylan last edited by
      Hi Everyone,
      Quite new to the recalbox world, I was using it with an old controller and I wanted to switch to an USB wired XBOX 360 controller (this one: https://www.amazon.com/PDP-Wired-Controller-Xbox-One-PC/dp/B01GOK309W). It works fine on my computer but as soon as i plug it into my RPi 1B it does not work. The LED of the controller does not turn on. I run the build 4.0.0 of recalbox.
      I modified the file recalbox.conf file to disable the ps controller and enable the xbox driver but it has no change on the issue. Does somebody have a hint on that?
      Thx
      100.7k
