    Confused - Where is the PSX Emulator?
    confused where psx
    7239
    • james-boggs
      james-boggs last edited by
      So I installed recalbox, booted, and only the SNES/NES/SMS/TG16 emulators are listed. How do I get the PSX emulator?
      • reivaax
        reivaax last edited by
        Hi ! 🙂 You need to add a rom PSX in the folder and reboot recalbox. Only the machine with roms is view un recalbox 🙂 More informations in the wiki 🙂 https://github.com/digitalLumberjack/recalbox-os/wiki/Manual-(EN)
        • james-boggs
          Haha thanks. I had my own ROMS own a USB drive attached, and figured I could add sources from a secondary, but I couldn't figure it out. Thanks much.
          • james-boggs
            So, how can I add my thumb drive as a media source?
            • reivaax
              Look in the wiki ! You have a looooot of response at your questions ;). https://github.com/digitalLumberjack/recalbox-os/wiki/Auto-mount-of-usb-in-place-of-share-partition-(EN) Hop that help you :). And you can try a search in the forum. http://blog.recalbox.com/forums/search/
              • james-boggs
                I set the mount in fstab, but it doesn't automount. No files are found. I can mount it manually at command line, but I can't seem to figure out why it fails at fstab
                • reivaax
                  Sorry, i use my sd card for my roms. I can't help you :/. Look in the forum. they have différent topic about usb drive... Hop that help you 😕
