    Recalbox Manager Monitoring Fix
    Recalbox
    recalbox manager monitoring fix
    • sevenx
      sevenx last edited by sevenx
      Hallo Zusammen
      Da ich aktuell mit der neusten Version unterwegs bin und diverse Probleme mit dem Manager Monitoring hatte, machte ich mir kurzerhand einen Fix:
      /usr/recalbox-manager/project/manager_frontend/views/monitor.py
      Folgenden Import hinzufügen unterhalb von import os:
      from subprocess import call
      Dann ca. Zeile 42 folgenden Inhalt:
      critical_limit = float(open(os.path.join(device_dir, RECALBOX_THERMAL_MAXTEMP_LIMIT_FILE), 'r').read().strip())
      mit folgendem Code ersetzen:
      •        try:
              except:
                  try:
                      critical_limit = float(call(["vcgencmd get_config int | grep temp_limit | cut -d '=' -f 2"]).strip())
                  except:
                      critical_limit = 85.0 * 1000.0*
      Zusätzlich habe ich die Temperatur mit einer Progressbar versehen
      /usr/recalbox-manager/project/manager_frontend/temapltes/manager_frontent/monitoring.html
      <!-- Ab Hier -->
      {% extends "manager_frontend/base.html" %}
      {% load i18n %}
      {% block manager_content %}
      {% if PSUTIL_AVAILABLE %}
      <div class="dashboard-system-infos">
      <div class="row cpu">
          <div class="small-12 columns">
              <p class="title-3">{% trans "CPU" %}</p>
          </div>
          {% for core_percent in cpu_infos.usage %}{% with core_int=core_percent|floatformat:"0" %}
          <div class="small-6 columns{% if forloop.last %} end{% endif %} core-item">
              <div class="row">
                  <div class="small-12 medium-4 columns core-number text-right">
                      <p>{% blocktrans with number=forloop.counter %}Core&nbsp;{{ number }}{% endblocktrans %}</p>
                  </div>
                  <div class="small-12 medium-8 columns core-usage-progress">
                      <div class="progress success radius">
                          <span class="meter" style="width: {{ core_int }}%"></span>
                          <span class="value">{{ core_int }}%</span>
                      </div>
                  </div>
              </div>
          </div>
          {% endwith %}{% endfor %}
      </div>
      <hr>
      <div class="row">
          <div class="small-12 columns medium-8">
              <div class="row memory">
                  {% with memory_usage_int=memory_infos.usage_percent|floatformat:"0" %}
                      <p class="title-3">{% trans "Memory" %}</p>
                  </div>
                  <div class="small-12 medium-3 columns medium-text-right free">
                      {% blocktrans with size=memory_infos.free_unified|filesizeformat %}Free: {{ size }}{% endblocktrans %}
                  </div>
                  <div class="small-12 medium-6 columns usage">
                          <span class="meter" style="width: {{ memory_usage_int }}%"></span>
                          <span class="value">{{ memory_usage_int }}%</span>
                      </div>
                  </div>
                  <div class="small-12 medium-3 columns medium-text-left total">
                      {% blocktrans with size=memory_infos.total|filesizeformat %}Total: {{ size }}{% endblocktrans %}
                  </div>
                  {% endwith %}
              </div>
          </div>
          <div class="small-8 columns medium-4 thermal-cpu-infos">
              <p class="title-3">{% trans "CPU Temperature" %}</p>
              <div class="row temperature">
                  <div class="small-8 columns">
                          {% with temp_percent_int=cpu_thermal_infos.percent_usage|floatformat:"0" %}
                          <span class="meter" style="width: {{ temp_percent_int }}%"></span>
                          <span class="value">{{ cpu_thermal_infos.current }}°c</span>
                          {% endwith %}
                      </div>
                  </div>
                  <div class="small-4 columns">
                      {% trans "Max" %}: {{ cpu_thermal_infos.max }}°c
                  </div>
              </div>
          </div>
      </div>
      <hr>
      <div class="row filesystem">
              <p class="title-3">{% trans "File system" %}</p>
              <table class="expand">
                  <thead>
                      <tr>
                          <th class="device">{% trans "Device" %}</th>
                          <th class="mountpoint">{% trans "Mount" %}</th>
                          <th class="type">{% trans "Type" %}</th>
                          <th class="usage">{% trans "Usage" %}</th>
                          <th class="used">{% trans "Used" %}</th>
                          <th class="free">{% trans "Free" %}</th>
                          <th class="total">{% trans "Total" %}</th>
                      </tr>
                  </thead>
                  <tbody>
                      {% for disk in filesystem_infos %}{% with usage_percent=disk.used_percent|floatformat:"0" %}
                      <tr class="device-item">
                          <td class="device">{{ disk.device }}</td>
                          <td class="mountpoint">{{ disk.mountpoint }}</td>
                          <td class="type">{{ disk.fstype }}</td>
                          <td class="usage">
                                  <span class="meter" style="width: {{ usage_percent }}%"></span>
                                  <span class="value">{{ usage_percent }}%</span>
                              </div>
                          </td>
                          <td class="used">{{ disk.used_bytes|filesizeformat }}</td>
                          <td class="free">{{ disk.free|filesizeformat }}</td>
                          <td class="total">{{ disk.total|filesizeformat }}</td>
                      </tr>
                  </tbody>
              </table>
          </div>
      </div>
      </div>
      {% endif %}
      {% endblock %}
      <!-- bis hier kopieren -->
      Nach erfolgreichem Speichern Recalbox neustarten oder den Manager neustarten.
