    Crearé my own shaderset
    Themes & Interface
    crearé own shaderset
    • 8bit_astronaut
      8bit_astronaut last edited by
      I want to crearé my own shaderset, the shaders installed in retroarch are great, and i want to use my favoritos with every system.
      How can i make that?
      I want my own list you know
        You can edit recalbox.conf and add for example snes.shaders=path or even global.shaders=...
        8bit_astronaut 1 Reply Last reply Reply Quote 0
        • 8bit_astronaut
          8bit_astronaut @Substring last edited by
          @Substring can i set a global shaders, and excepcional shaders?
          For example, i want every console with this shaders, excepto gba.
          Its posible to do that?
            Substring @8bit_astronaut last edited by
            @8bit_astronaut yep, core specific shaders override global shaders
            • 8bit_astronaut
              @Substring thank you so much for your help
              101.0k
