    PS3 Bluetooth connectivity
    GamePad/GPIO/USB encoder
    ps3 bluetooth connectivity
    9805
    • Bowzer Mike
      Bowzer Mike last edited by
      Do I need to plug my ps3 remote in every time I want to sync it with my Bluetooth dongle?
      • Anonpebbles
        Anonpebbles last edited by
        Do you have the driver set in your config file?
        Bowzer Mike 2 Replies Last reply Reply Quote 0
        • Bowzer Mike
          Bowzer Mike @Anonpebbles last edited by
          @davidwrightini I got it pre-loaded so I have no idea,
          • Bowzer Mike
            @davidwrightini Would I need to do this
            https://github.com/recalbox/recalbox-os/wiki/Connect-bluetooth-controller-with-hcitool-and-hidd-manually-(EN)
            • Anonpebbles
              Perhaps, but first connect to your pi via your browser (type in it's ip, 192.168.1.***) and go to the config page
              scroll down to PS3 controller and make sure it's enabled with the correct driver. Also make sure xbox pads are disabled. Then try doing the manual connect via putty
              Bowzer Mike 1 Reply Last reply Reply Quote 0
              • Bowzer Mike
                Bowzer Mike @Anonpebbles last edited by Nachtgarm
                @davidwrightini here is what it has
                controllers.ps3.enabled=1
                ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
                controllers.xboxdrv.enabled=0
                ## GPIO Controllers
                controllers.gpio.enabled=0
                controllers.gpio.args=map=1,2
                ## DB9 Controllers
                controllers.db9.enabled=0
                ## db9 arguments
                controllers.db9.args=map=1
                ## Gamecon controllers
                controllers.gamecon.enabled=0
                ## gamecon_args
                controllers.xarcade.enabled=1
                • Anonpebbles
                  Looks fine. You might want to check that your bluetooth dongle is compatible using the compatibility list.
                  • Bowzer Mike
                    @davidwrightini I did and it is. Its not a huge deal just kinda sucks I have to plug em in everytime I boot up my system. Thanks for taking a look and tryin to help! Greatly appreciated =D
                    • linuxxx82
                      linuxxx82 last edited by
                      interesting topic,
                      i found out that the "plug and play" bluetooth dongle works well, when ever i do a reboot of my Pi, I just have to pair it ( pressing the hotkey button)..
                      what google cant provide me tho is that i now have to link a second wireless Ps3 controller.
                      what do i do?. do i unplug my first controller blue tooth first,
                      is it best to rather get a wired controller??
                      HELP
                      thanks
                      • Bowzer Mike
                        Bowzer Mike @linuxxx82 last edited by
                        @linuxxx82 I just plugged my second one in once the Bluetooth picked up the first controller and it seems once one is picked up the other one it good to go. but yeah try just plugging it in after you get one recognized
                        • Bowzer Mike
                          @linuxxx82 So far the easiest remote to set up has been the xbox360 remotes with the wireless PC dongle
                          • Anonpebbles
                            @Bowzer-Mike No worries sorry I couldn't be of any help! I too have had trouble getting ps3 controllers to work over Bluetooth ;_;
