    XBMC back into Emulationstation
    xbmc
    12
    25
    10752
    • menappi
      menappi last edited by
      When my diy Recalbox starts up it starts with the Emulation portion, I hit X to go into XBMC, which is fine. When I try to 'shut down' XBMC it then goes back into Emulationstation but the resolution is all compressed and the controller doesn't respond. How do I 1) shutdown XBMC and the entire Raspberry Pi 2)go from XBMC back into Emulationstation with proper resolution and controller functionality???
      • nickdj
        nickdj last edited by
        This happens if Kodi/XBMC is at a different resolution to EmulationStation. Just change the settings within Kodi to match (usually the highest setting). 🙂
        RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
        • darky_mtp
          darky_mtp last edited by
          Edit /recalbox/scripts/kodilauncher.sh Change kill $pid to kill -9 $pid
          • menappi
            I'm not exactly sure how to do this. I've put my micro sd card into my computer but I can't find those paths/files. Even less sure how i'd do this from the raspberry pi directly..any help? Also..what exactly does this do? Fix the resolution or completely shut down the device when hitting shutdown from xbmc?
            • menappi
              I'll try to adjust but will this fix the issue with the controller not responding when quitting kodi/xbmc?
              • darky_mtp
                Yes it will.
                • nickdj
                  Use SSH (e.g. Putty) to log into recalbox Username: root Password: recalboxroot type 'nano /recalbox/scripts/kodilauncher.sh' Change kill $pid to kill -9 $pid Press Ctrl+x Press 'y' to save Press 'Enter' overwrite the file I've experienced a few times where neither the keyboard or controller work after exiting Kodi but not all the time. However, what I have noticed is TVaddons (Fusion) is working and I can install it in full! 🙂
                  • jose-luis-reyes
                    jose-luis-reyes last edited by
                    Thanks, but... What I do wrong?
                    • reggaemanu
                      reggaemanu last edited by
                      You forgot the space between nano and /
                      • jose-luis-reyes
                        Exactly. thanks friend. 🙂
                        • digitaLumberjack
                          Corrected that in https://github.com/digitalLumberjack/recalbox-buildroot/commit/4150045773fa3c2cdb5a93b8269a81cff18a56ba
                          • nickdj
                            Thanks for that. I amended the line rather than adding a new line. Will try it out as I would like to be able to shut down from Kodi too.
                            • bluelightcrew
                              bluelightcrew last edited by
                              I have the same problem,but my recalbox autostarts Kodi.I have changed kill $pid to kill -9 $pid,but when i ‘shut down’ Kodi it then goes back into Emulationstation.
                              • darky_mtp
                                Actually "shutdown" or "exit" will bring you to emulationstation. To shutdown the raspberry pi you have to do it from emulationstation.
                                • bluelightcrew
                                  Ah ok thanks. Is it a bug, so it can be fixed in future, or is there nothing to do?
                                  • nickdj
                                    Just a thought, is the an add-on within Kodi which can run a linux command? I'm wondering if it's possible to issue a shutdown from that?
                                    • cyrixblack
                                      cyrixblack last edited by
                                      Also worth asking what shutdown command can we do coz shutdown -h now doesn't work?
                                      • nickdj
                                        systemctl poweroff? Not near my recalbox to test.
                                        • jassen-payen
                                          jassen-payen last edited by
                                          Hi, I would also like to be able to shutdown Kodi directly without going back to Emulation Station. I actually start recalbox directly in Kodi, so this would make it almost perfect for me. Thanks!
                                          • ivwshane
                                            ivwshane last edited by
                                            I have a friend experiencing this same issue where the wireless xbox controller stops working after exiting kodi. Will this fix be in the next release or is it in the current public release?
