    [SOFT] Romset cleaner - multi os
    Community projects
    [soft] romset cleaner multi
    • azzra
      azzra last edited by
      Hi,
      inspired by Screech's Universal-ROM-Cleaner, here is romset cleaner written in Go so it should be working on Linux, OS X & Windows: https://github.com/azzra/romset-cleaner
      It use a really simple algorithm and have less options than the original but should be working properly.
      Let me know if you have any issue!
      100.7k
