    GPIO joystick and buttons issue
    GamePad/GPIO/USB encoder
    gpio joystick buttons issue
    15928
    • facpo
      facpo last edited by
      Hello,
      I am making a bartop Arcade using Recalbox and I have issues when it comes to set a controller on the recalbox interface, I plug all my buttons on the gpio using this guide: https://github.com/recalbox/recalbox-os/wiki/GPIO-controllers-(FR)
      The problem is when I try to set up a new controller, every pushbuttons are working, but when I try to configure them, after I set one, the other ones are not working anymore.
      I Know im not super clear, english is not my first language, but in other words, i can only configure one push buttons than the other one just dosen't work anymore...
      If this ring a bell to anyone of you please respond it would be super appreciated.
      Thank you, Francois
        shall I move your message to the french section and answer you in french ?
        • facpo
          I was about to ask on the french forum also, but i would let this on the english forum, the more anwser the merrier!
            Meanwhile test your GPIO sticks with evtest
            https://github.com/recalbox/recalbox-os/wiki/Test-your-joystick-with-jstest-(EN)
            jstest is almost the same, though it's deprecated
            • Jean-marc Strauven
              Jean-marc Strauven last edited by
              Hello,
              I have the same issue and all the test (evtest, jstest) are ok..
              have you a solution ?
              JMS
                Substring @Jean-marc Strauven last edited by
                @jean-marc-strauven does evtest output strictly different event names when you try each button/stick direction ?
                • IvoLourenco
                  IvoLourenco last edited by
                  @Substring I was trying to test my GPIO using the jstest. Basically it gives me the error 'jstest: command not found'. I follow the instructions of https://github.com/recalbox/recalbox-os/wiki/Test-your-joystick-with-jstest-(EN).
                  This issue that i'm having is: When i try to set up my controller the joystick works and the A button. Apart from that none of the other buttons work. Anyone experienced similiar issue?
                    Substring @IvoLourenco last edited by
                    @ivolourenco most obably a wiring issue. Use evtest instead of jstest
                    • IvoLourenco
                      @Substring so i did a evtest GPIO detected as within recalbox. All buttons worked (how can i save the log of events to share with you?)
                      I even did a wiring direct to the GPIO for individual buttons to remove the wiring possibility (e.g daisy chain ground).
                      Any other ideia?
                        @ivolourenco has every single button returned a different event ?
                        To share what you did, juste select the text in putty (it's automatically copied, that's a linux habbit) and paste it here between triple back quotes
                        • IvoLourenco
                          @Substring output from the evtest below.
                          Sequence was: js up; js down; js left; js right; B; A; TR; TL; X; Y; Start; Select.
                          So i would imagine that all the setup is ok. However, within the Recalbox is not detected.
                          I have a daisy chain ground that runs on all the buttons and is connected to the GPIO 6 any potential issue with that?
                          """No device specified, trying to scan all of /dev/input/event*
                          Available devices:
                          /dev/input/event0: NOVATEK USB Keyboard
                          /dev/input/event1: NOVATEK USB Keyboard
                          /dev/input/event2: GPIO Controller 1
                          /dev/input/event3: GPIO Controller 2
                          Select the device event number [0-3]: 2
                          Input driver version is 1.0.1
                          Input device ID: bus 0x15 vendor 0x1 product 0x1 version 0x100
                          Input device name: "GPIO Controller 1"
                          Supported events:
                          Event type 0 (EV_SYN)
                          Event type 1 (EV_KEY)
                          Event code 304 (BTN_SOUTH)
                          Event code 305 (BTN_EAST)
                          Event code 307 (BTN_NORTH)
                          Event code 308 (BTN_WEST)
                          Event code 310 (BTN_TL)
                          Event code 311 (BTN_TR)
                          Event code 314 (BTN_SELECT)
                          Event code 315 (BTN_START)
                          Event code 316 (BTN_MODE)
                          Event type 3 (EV_ABS)
                          Event code 0 (ABS_X)
                          Value 0
                          Min -1
                          Max 1
                          Event code 1 (ABS_Y)
                          Value 0
                          Min -1
                          Max 1
                          Properties:
                          Testing ... (interrupt to exit)
                          Event: time 315536585.570709, type 3 (EV_ABS), code 1 (ABS_Y), value 1
                          Event: time 315536585.570709, -------------- SYN_REPORT ------------
                          Event: time 315536585.780727, type 3 (EV_ABS), code 1 (ABS_Y), value 0
                          Event: time 315536585.780727, -------------- SYN_REPORT ------------
                          Event: time 315536587.760702, type 3 (EV_ABS), code 1 (ABS_Y), value -1
                          Event: time 315536587.760702, -------------- SYN_REPORT ------------
                          Event: time 315536587.970709, type 3 (EV_ABS), code 1 (ABS_Y), value 0
                          Event: time 315536587.970709, -------------- SYN_REPORT ------------
                          Event: time 315536589.990696, type 3 (EV_ABS), code 0 (ABS_X), value 1
                          Event: time 315536589.990696, -------------- SYN_REPORT ------------
                          Event: time 315536590.160719, type 3 (EV_ABS), code 0 (ABS_X), value 0
                          Event: time 315536590.160719, -------------- SYN_REPORT ------------
                          Event: time 315536591.750714, type 3 (EV_ABS), code 0 (ABS_X), value -1
                          Event: time 315536591.750714, -------------- SYN_REPORT ------------
                          Event: time 315536591.910707, type 3 (EV_ABS), code 0 (ABS_X), value 0
                          Event: time 315536591.910707, -------------- SYN_REPORT ------------
                          Event: time 315536598.760726, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 0
                          Event: time 315536598.760726, -------------- SYN_REPORT ------------
                          Event: time 315536598.930715, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 1
                          Event: time 315536598.930715, -------------- SYN_REPORT ------------
                          Event: time 315536603.350710, type 1 (EV_KEY), code 305 (BTN_EAST), value 0
                          Event: time 315536603.350710, -------------- SYN_REPORT ------------
                          Event: time 315536603.520718, type 1 (EV_KEY), code 305 (BTN_EAST), value 1
                          Event: time 315536603.520718, -------------- SYN_REPORT ------------
                          Event: time 315536686.300702, type 1 (EV_KEY), code 311 (BTN_TR), value 0
                          Event: time 315536686.300702, -------------- SYN_REPORT ------------
                          Event: time 315536686.500701, type 1 (EV_KEY), code 311 (BTN_TR), value 1
                          Event: time 315536686.500701, -------------- SYN_REPORT ------------
                          Event: time 315536692.130701, type 1 (EV_KEY), code 310 (BTN_TL), value 0
                          Event: time 315536692.130701, -------------- SYN_REPORT ------------
                          Event: time 315536692.330698, type 1 (EV_KEY), code 310 (BTN_TL), value 1
                          Event: time 315536692.330698, -------------- SYN_REPORT ------------
                          Event: time 315536702.220730, type 1 (EV_KEY), code 307 (BTN_NORTH), value 0
                          Event: time 315536702.220730, -------------- SYN_REPORT ------------
                          Event: time 315536702.430694, type 1 (EV_KEY), code 307 (BTN_NORTH), value 1
                          Event: time 315536702.430694, -------------- SYN_REPORT ------------
                          Event: time 315536709.500750, type 1 (EV_KEY), code 308 (BTN_WEST), value 0
                          Event: time 315536709.500750, -------------- SYN_REPORT ------------
                          Event: time 315536709.690705, type 1 (EV_KEY), code 308 (BTN_WEST), value 1
                          Event: time 315536709.690705, -------------- SYN_REPORT ------------
                          Event: time 315536714.390708, type 1 (EV_KEY), code 315 (BTN_START), value 0
                          Event: time 315536714.390708, -------------- SYN_REPORT ------------
                          Event: time 315536714.570710, type 1 (EV_KEY), code 315 (BTN_START), value 1
                          Event: time 315536714.570710, -------------- SYN_REPORT ------------
                          Event: time 315536716.760701, type 1 (EV_KEY), code 314 (BTN_SELECT), value 0
                          Event: time 315536716.760701, -------------- SYN_REPORT ------------
                          Event: time 315536716.940702, type 1 (EV_KEY), code 314 (BTN_SELECT), value 1
                          Event: time 315536716.940702, -------------- SYN_REPORT ------------"""
                            @ivolourenco So, each of the buttons are working properly and independantly. The daisy chain is just for the ground, and should link a pin of each switch to the Pi ground.
                            You're not supposed to remap the controller in ES, it's configured by default. Try those commands in SSH :
                            /etc/init.d/S31emulationstation stop
                            cp /recalbox/share_init/system/.emulationstation/es_input.cfg ~/.emulationstation
                            /etc/init.d/S31emulationstation start
                            And try your stick without reconfiguring it for now
                            • IvoLourenco
                              @Substring see the outup of those commands:
                              """ # /etc/init.d/S31emulationstation stop
                              lvl0: Could not find <gameList> node in gamelist "/recalbox/share/roms/amstradcpc/gamelist.xml"!
                              lvl0: Could not find <gameList> node in gamelist "/recalbox/share/roms/snes/gamelist.xml"!
                              lvl0: Could not find <gameList> node in gamelist "/recalbox/share/roms/gba/gamelist.xml"!
                              ERROR - tried to write to log file before it was open! The following won't be logged:
                              lvlERROR - tried to write to log file before it was open! The following won't be logged:
                              cp /recalbox/share_init/system/.emulatoions
                              BusyBox v1.25.1 (2017-10-12 19:45:17 UTC) multi-call binary.
                              Usage: cp [OPTIONS] SOURCE... DEST
                              Copy SOURCE(s) to DEST
                                  -a      Same as -dpR
                                  -R,-r   Recurse
                                  -d,-P   Preserve symlinks (default if -R)
                                  -L      Follow all symlinks
                                  -H      Follow symlinks on command line
                                  -p      Preserve file attributes if possible
                                  -f      Overwrite
                                  -i      Prompt before overwrite
                                  -l,-s   Create (sym)links
                                  -u      Copy only newer files
                              lvl0: System "favorites" is missing name, path, extension, or command!
                              lo IP Address 127.0.0.1
                              eth0 IP Address 169.254.119.52
                              curl: (6) Couldn't resolve host 'recaleur-archive-prod.recalbox.com'' """
                              Note: The joystick works withing the recalbox. But none the button work still.
                                @ivolourenco said in GPIO joystick and buttons issue:
                                This is not the command I wrote, please read again
                                • IvoLourenco
                                  @Substring sorry for that, output below.
                                  """# /etc/init.d/S31emulationstation stop
                                      -a      Same as -dpR
                                      -R,-r   Recurse
                                      -f      Overwrite
                                  curl: (6) Couldn't resolve host 'recaleur-archive-prod.recalbox.com'"""
                                    @ivolourenco the cp command is not correctly typed. I tried it on my recalbox and it works.
                                    When reporting, please use such `bback quotes, not double quotes
                                    • IvoLourenco
                                      @Substring All buttons responding. Seems incorrectly setup though. Shall I remap them?
                                      And what have i done... with the commands you suggested?
                                      # lvl0:         Could not find <gameList> node in gamelist "/recalbox/share/roms/amstradcpc/gamelist.xml"!
                                      # cp /recalbox/share_init/system/.emulations/es_input.cfg ~/
                                      cp: can't stat '/recalbox/share_init/system/.emulations/es_input.cfg': No such file or directory
                                      # cp /recalbox/share_init/system/.emulationstation/es_input.cfg ~/.emulationstation
                                      # /etc/init.d/S31emulationstation start
                                        @ivolourenco Incorrectly setup ? If you followed the wiring diagram + buttons layout like :
                                        Y X L
                                        B A X
                                        You shouldn't have to remap. But ok, try remapping now you know how to reset the mapping 😉
                                        IvoLourenco 1 Reply Last reply Reply Quote 0
                                        • IvoLourenco
                                          IvoLourenco @Substring last edited by IvoLourenco
                                          @substring going to start drilling the button now! 😄
                                          I just noticed that when i push up it goes down... so may be there is a issue on the setup of wiring.
                                          However, I did a run on remapping but it still does not recognise after A button 😞
                                          Thanks
                                            @ivolourenco can you go to http://recalbox while trying to remap, and make a screenshot of Recalbox when you're stuck at remapping ? You can post it here using the small cloud icon with an arrow, no need to drop it on some website
