    Shaders (tons of them)
    Your discoveries
    shaders tons
    15380
    • 8bit_astronaut
      8bit_astronaut last edited by
      i'v just discovered this blog that have tons and tons of shaders!
      http://filthypants.blogspot.cl/2016/03/new-and-updated-shaders.html
      Just look at them, they are beautiful, and with a lot of variety!
      For example this CRT-Royale-Kurozumi Preset, its just beautiful!
      I want to add some of them to recalbox, but i can´t, i followed the guide and everything but...no luck 😕
      Someone could try to add them? maybe add it to the next recalbox beta version?
      They would add a lot of variety from theshaders that ae actually in recalbox, because they all look the same.
      Have a nice day!
      belgianfred 1 Reply Last reply Reply Quote 0
        That's the blog from HunterK, a retroarch dev 😮
        • belgianfred
          belgianfred @8bit_astronaut last edited by belgianfred
          Hello,
          Thanks for your post, thanks to it i find the shaders i was looking for.
          I zip them in an archive wih screen shot comparison.
          Depending on the emulator; i generaly use shader preset: hq2x.glslp (under retroarch menu / quickmenu / shaders / load shader preset).
          Please not that is for use on LCD fullHD screen to give best smooth and sharp picture.
          Shaders archive - Alternate link
          0_1477794267616_RetroArch-1030-030414.png 23_1477794281038_RetroArch-1030-030636.png 22_1477794281038_RetroArch-1030-030632.png 21_1477794281038_RetroArch-1030-030627.png 20_1477794281038_RetroArch-1030-030624.png 19_1477794281038_RetroArch-1030-030620.png 18_1477794281038_RetroArch-1030-030616.png 17_1477794281038_RetroArch-1030-030607.png 16_1477794281038_RetroArch-1030-030605.png 15_1477794281038_RetroArch-1030-030601.png 14_1477794281037_RetroArch-1030-030559.png 13_1477794281037_RetroArch-1030-030556.png 12_1477794281037_RetroArch-1030-030553.png 11_1477794281037_RetroArch-1030-030550.png 10_1477794281037_RetroArch-1030-030546.png 9_1477794281037_RetroArch-1030-030543.png 8_1477794281037_RetroArch-1030-030539.png 7_1477794281037_RetroArch-1030-030533.png 6_1477794281037_RetroArch-1030-030529.png 5_1477794281037_RetroArch-1030-030523.png 4_1477794281036_RetroArch-1030-030520.png 3_1477794281036_RetroArch-1030-030516.png 2_1477794281036_RetroArch-1030-030512.png 1_1477794281036_RetroArch-1030-030508.png 0_1477794281036_RetroArch-1030-030504.png
          Bye.
          8bit_astronaut 1 Reply Last reply Reply Quote 1
          • cotedeporc
            cotedeporc last edited by
            Thanks!
            Very useful!!
            Thème FoolScreen / Squared
            • 8bit_astronaut
              8bit_astronaut @belgianfred last edited by
              @belgianfred sorry for asking you this, but how could you make the shaders work on recalbox?
              I followed the guide step by step to install some of them but i had no look 😕
              • belgianfred
                @8bit_astronaut Hello,
                i downloaded thoses shaders and extract them in recalbox/share/system/shaders
                GLSLP= shader preset (generally several passes some kind of "shader loading profile")
                GLSL= shader file.
                and modify this line in= /recalbox/share/system/recalbox.conf
                Set gpslp shader for all emulators (prefer shadersets above).
                Absolute path (string) global.shaders=
                /recalbox/share/system/shaders/hq2x.glslp
                At this point; ingame you can test them (see shortcut in retroarch config).
                That set up recalbox to ask retroarch to use hq2xl.glsl shader with all libretro emulators. (exept fba)
                • 8bit_astronaut
                  This post is deleted!
                  • 8bit_astronaut
                    @belgianfred Ok for example i tried with two shaders the first crt-royale, and the second one phosphor21x, but i cant make it work on Recalbox ><
                    Im sorry for asking you this but...could you please help me with those...?
