    Solved Custom SimpleLight theme - Cover Rom size
    Themes & Interface
    simplelight theme cover rom size
    5835
    • colera100dragoes
      colera100dragoes last edited by colera100dragoes
      Hello Everyone,
      I like to use the theme Simple Light in recalbox, however the images of the roms are very small.
      Does anyone know how to increase the cover image of the roms as in Eudora_bigshot theme?
      • Nachtgarm
        Nachtgarm @colera100dragoes last edited by
        @colera100dragoes You have to edit all respective XML files, but not only the size of the pictures; You need to edit everything, since the positioning in ES is absolute and will overlay each other. So if you just edit the ROM size part, everything else will be hidden below it, or even cover the picture. Can't remember the order in the XML file at the moment. So maybe you just want to use another theme, if you're not willing to get into ES themeing and XML coding, or you need to make yourself familiar with it. 🙂
        colera100dragoes 1 Reply Last reply Reply Quote 0
        • colera100dragoes
          colera100dragoes @Nachtgarm last edited by
          Hi @Nachtgarm ,
          Thanks for your help.
          I changed the theme and I like it a lot.
          drummer6656 1 Reply Last reply Reply Quote 0
          • Nachtgarm
            You're welcome @colera100dragoes.
            • drummer6656
              drummer6656 @colera100dragoes last edited by
              @colera100dragoes How did you change it? Thats exactly what I want to do.
              • VĂ­ctor TĂ©llez
                Víctor Téllez last edited by
                I've change the xml settings for each system for a bigger screenshots.
                Please take a look at it: https://forum.recalbox.com/topic/5774/my-final-custom-recalbox-4-1-theme-background-images-sounds-and-logos
