    Unsolved Issue with composite video on Raspberry Pi Zero 2W
    issue composite zero
    • aldisguy
      aldisguy last edited by
      Hi im new to all this and I'm building a Game Boy Zero with a Raspberry Pi Zero 2W running Recalbox 9.2.3. Im using a TFT LCD screen for it that ive modified to run on 5V and tested it with a DVD player and it works. But when i try to use it with my Raspberry Pi the screen stays completely black.
      I connected the yellow composite signal wire to GPIO18 with and without a 180ohm resistor which i beleive is supposed to be used instead of the TV pad on a Raspberry Pi Zero that isnt there on a Zero 2W.
      I also edited the recalbox-boot.conf file and added global.enable_tvout=1 and global.videooutput=COMPOSITE. Then i also changed to global.videomode=default in the recalbox.conf file in the share partion. after that didnt work i also tried adding:
      enable_tvout=1
      sdtv_mode=2 # 0 for NTSC or 2 for PAL
      sdtv_aspect=1
      disable_overscan=1
      hdmi_ignore_hotplug=1
      to config.txt. I know im not supposed to edit that file but its just for testing.
      I feel like nothings working so if anyone has any ideas or if im doing anything wrong which i probably am please let me know thank you.
      • Topic has been marked as a question  aldisguy aldisguy
      100.7k
