    Controller not configured in Mupen64
    GamePad/GPIO/USB encoder
    configured mupen64
    • lagerzero
      lagerzero last edited by
      Hey guys I don't know if you came up with this problem.
      For gaming with the recalbox system i'm using a [DragonRise Inc. Generic USB Joystick] and a [SWITCH CO.,LTD. Controller (Dinput)].
      Now when I start a N64 game I alway get the warning of my controler not configured
      I tried this https://wiki.recalbox.com/en/tutorials/controllers/configuration-of-customized-buttons/n64-controller-configuration
      but it did not work.
      I also mostly use the parallel n64 emulator and the mupen63Plus next since my file are mostly .zip only a few are using the piko and the mk2.
      I can see that in my InputAutoCfg.ini the controller are both there and configured properly. So why even though in retroarch my autoconfig is on and pointing to the mupen64 folder for input data. Why does it not recognise my configuration. Which part should I change for it to recognise it? Please help!
      • lagerzero
        Solved it`s this part that was not configured properly and it only wotk with mupen64 mk2 and rice
        Configuration recalbox.conf
        Editer le fichier /recalbox/share/system/recalbox.conf
        in the n64 at the end we need to add this :
        n64.configfile=dummy
