    Solved Unhide roms
    Emulator Arcade/PC/Console
    unhide roms
    • Luciano Silva
      Luciano Silva last edited by
      I've made a mistake and hide a few roms from the emulationstation menu.
      How can i unhide them?
      Thanks.
      • DjLeChuck
        DjLeChuck last edited by
        I think the only solution is to manually edit the game_list.xml file from your emulator folder via the share folder.
        There is a parameter for hidding roms
          Hello, indeed, for the moment, there is no option in ES to unhide roms.
          So as said by @DjLeChuck you must edit your gamelist.xml file inside your /share/roms/SYSTEM folder.
          But, before editing this file, you must close ES (emulationstation).
          If you have a keyboard plugged on your recalbox, you can press F4, or on ssh, use one of these commands :
          killall emulationstation or /etc/init.d/S31emulationstation stop
          You can now edit your gamelist.xml file, find your game entry, then switch hide option from true to false.
          • Luciano Silva
            I´m using the same folder for two diferent emulators.
            I renamed the two files and manually added them to my gamelist.xml
            Thanks.
