    Waveshre 5.5inch 1440x2560 LCD
    waveshre 5.5inch 1440x2560 lcd
    • djsedaw
      djsedaw last edited by
      Trying to setup a 5.5inch 1440x2560 LCD screen in recallbox, if i paste the txt below in to user config from the waveshare wiki, it will work in portrate mode but es will not load, if i use the set resolution method in the recallbox wicki, i just get 5 repeated images in portrate but es will load
      hvs_priority=0x32ff
      gpu_mem=256
      config_hdmi_boost=10
      hdmi_force_hotplug=1
      hdmi_group=2
      hdmi_mode=87
      hdmi_drive=2
      hdmi_pixel_freq_limit=268500000
      #pi4:
      hdmi_timings=1440 0 10 10 140 2560 0 11 2 2 0 0 0 50 0 206000000 3
      #3B/ZERO needs to change to the following line of timings configuration and block dtoverlay=vc4-kms-v3d or dtoverlay=vc4-fkms-v3d
      #hdmi_timings=1440 0 10 10 140 2560 0 11 2 2 0 0 0 50 0 180000000 3
      disable_overscan=1
      framebuffer_width=1440
      framebuffer_height=2560
      max_framebuffer_width=1440
      max_framebuffer_height=2560
      extra_transpose_buffer=2
      • PaxtonKingsley
        PaxtonKingsley last edited by PaxtonKingsley
        Hello, everyone. I am new here.
