    Gpio controler number 1 doesn't work correctly in interface
    GamePad/GPIO/USB encoder
    gpio contoller
    • dreamkiller
      dreamkiller last edited by dreamkiller
      • Raspberry Pi/ Odroid / PC / NUC model: Raspberry PI3B
      • Recalbox version (build) : 9.2.3
      • Hardware (Micro SD, Power Supply, etc.): Micro SD 128 Go san disk for the OS, 128 or 256 Go ssd drive in usb without external alimentation
      • Controller(s): GPIO
      Hi,
      I have a strange behavior with my GPIO 1 in recalbox interface (gpio2 works suite well) in mame game thé joystick and some button works (but not the hotkey...) .
      I double check the wire all seems correct
      I try a reinstall and a fallback to Factory parameters.
      Here are the Line of the recalbox.conf:
      controllers.gpio.enabled=1
      controllers.gpio.args=map=1,2 gpio=17,4,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,13,6,19,26,21,20,16,12,7,8,-1
      Hère are the first evtest (i change thé start and select buttons After seing a different state
      # evtest
      No device specified, trying to scan all of /dev/input/event*
      Available devices:
      /dev/input/event0:      NOVATEK USB Keyboard
      /dev/input/event1:      NOVATEK USB Keyboard System Control
      /dev/input/event2:      NOVATEK USB Keyboard Consumer Control
      /dev/input/event3:      NOVATEK USB Keyboard
      /dev/input/event5:      vc4-hdmi
      /dev/input/event6:      GPIO Controller 1
      /dev/input/event7:      GPIO Controller 2
      Select the device event number [0-7]: 6
      Input driver version is 1.0.1
      Input device ID: bus 0x15 vendor 0x1 product 0x1 version 0x100
      Input device name: "GPIO Controller 1"
      Supported events:
        Event type 0 (EV_SYN)
        Event type 1 (EV_KEY)
          Event code 304 (BTN_SOUTH)
          Event code 305 (BTN_EAST)
          Event code 307 (BTN_NORTH)
          Event code 308 (BTN_WEST)
          Event code 310 (BTN_TL)
          Event code 311 (BTN_TR)
          Event code 314 (BTN_SELECT)
          Event code 315 (BTN_START)
          Event code 316 (BTN_MODE)
        Event type 3 (EV_ABS)
          Event code 0 (ABS_X)
            Value      0
            Min       -1
            Max        1
          Event code 1 (ABS_Y)
            Value      0
            Min       -1
            Max        1
      Properties:
      Testing ... (interrupt to exit)
      Joystick up
      Event: time 1733684350.972062, type 3 (EV_ABS), code 1 (ABS_Y), value -1
      Event: time 1733684350.972062, -------------- SYN_REPORT ------------
      Event: time 1733684351.172074, type 3 (EV_ABS), code 1 (ABS_Y), value 0
      Event: time 1733684351.172074, -------------- SYN_REPORT ------------
      Joystick down
      Event: time 1733684415.202073, type 3 (EV_ABS), code 1 (ABS_Y), value 1
      Event: time 1733684415.202073, -------------- SYN_REPORT ------------
      Event: time 1733684415.302067, type 3 (EV_ABS), code 1 (ABS_Y), value 0
      Event: time 1733684415.302067, -------------- SYN_REPORT ------------
      Joystick left
      Event: time 1733684482.892090, type 3 (EV_ABS), code 0 (ABS_X), value -1
      Event: time 1733684482.892090, -------------- SYN_REPORT ------------
      Event: time 1733684483.092086, type 3 (EV_ABS), code 0 (ABS_X), value 0
      Event: time 1733684483.092086, -------------- SYN_REPORT ------------
      Joystick right
      Event: time 1733684548.622071, type 3 (EV_ABS), code 0 (ABS_X), value 1
      Event: time 1733684548.622071, -------------- SYN_REPORT ------------
      Event: time 1733684548.742064, type 3 (EV_ABS), code 0 (ABS_X), value 0
      Event: time 1733684548.742064, -------------- SYN_REPORT ------------
      Select
      Event: time 1733684656.592131, type 1 (EV_KEY), code 314 (BTN_SELECT), value 1
      Event: time 1733684656.592131, -------------- SYN_REPORT ------------
      Event: time 1733684656.672139, type 1 (EV_KEY), code 314 (BTN_SELECT), value 0
      Event: time 1733684656.672139, -------------- SYN_REPORT ------------
      Start
      Event: time 1733684605.772092, type 1 (EV_KEY), code 315 (BTN_START), value 1
      Event: time 1733684605.772092, -------------- SYN_REPORT ------------
      Event: time 1733684605.872137, type 1 (EV_KEY), code 315 (BTN_START), value 0
      Event: time 1733684605.872137, -------------- SYN_REPORT ------------
      Hotkey
      Event: time 1733684728.522082, type 1 (EV_KEY), code 316 (BTN_MODE), value 0
      Event: time 1733684728.522082, -------------- SYN_REPORT ------------
      Event: time 1733684728.642083, type 1 (EV_KEY), code 316 (BTN_MODE), value 1
      Event: time 1733684728.642083, -------------- SYN_REPORT ------------
      Y
      Event: time 1733684830.252108, type 1 (EV_KEY), code 308 (BTN_WEST), value 0
      Event: time 1733684830.252108, -------------- SYN_REPORT ------------
      Event: time 1733684830.392098, type 1 (EV_KEY), code 308 (BTN_WEST), value 1
      Event: time 1733684830.392098, -------------- SYN_REPORT ------------
      X
      Event: time 1733684830.712106, type 1 (EV_KEY), code 307 (BTN_NORTH), value 0
      Event: time 1733684830.712106, -------------- SYN_REPORT ------------
      Event: time 1733684830.892098, type 1 (EV_KEY), code 307 (BTN_NORTH), value 1
      Event: time 1733684830.892098, -------------- SYN_REPORT ------------
      B
      Event: time 1733684831.172109, type 1 (EV_KEY), code 305 (BTN_EAST), value 0
      Event: time 1733684831.172109, -------------- SYN_REPORT ------------
      Event: time 1733684831.352094, type 1 (EV_KEY), code 305 (BTN_EAST), value 1
      Event: time 1733684831.352094, -------------- SYN_REPORT ------------
      A
      Event: time 1733684831.632099, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 0
      Event: time 1733684831.632099, -------------- SYN_REPORT ------------
      Event: time 1733684831.812099, type 1 (EV_KEY), code 304 (BTN_SOUTH), value 1
      Event: time 1733684831.812099, -------------- SYN_REPORT ------------
      L
      Event: time 1733684964.852089, type 1 (EV_KEY), code 310 (BTN_TL), value 0
      Event: time 1733684964.852089, -------------- SYN_REPORT ------------
      Event: time 1733684964.972089, type 1 (EV_KEY), code 310 (BTN_TL), value 1
      Event: time 1733684964.972089, -------------- SYN_REPORT ------------
      R
      Event: time 1733684964.172088, type 1 (EV_KEY), code 311 (BTN_TR), value 0
      Event: time 1733684964.172088, -------------- SYN_REPORT ------------
      Event: time 1733684964.332100, type 1 (EV_KEY), code 311 (BTN_TR), value 1
      Event: time 1733684964.332100, -------------- SYN_REPORT ------------
      After changing the start and select buttons i have :
      Event: time 1733687017.354101, type 1 (EV_KEY), code 315 (BTN_START), value 0
      Event: time 1733687017.354101, -------------- SYN_REPORT ------------
      Event: time 1733687017.454108, type 1 (EV_KEY), code 315 (BTN_START), value 1
      Event: time 1733687017.454108, -------------- SYN_REPORT ------------
      Event: time 1733687018.264103, type 1 (EV_KEY), code 314 (BTN_SELECT), value 0
      Event: time 1733687018.264103, -------------- SYN_REPORT ------------
      Event: time 1733687018.384107, type 1 (EV_KEY), code 314 (BTN_SELECT), value 1
      Event: time 1733687018.384107, -------------- SYN_REPORT ------------
      IS the stand-by status of the Switch important in the correct operation of the system?
      Did i forgot something for making the interface working correctly?
