    Can't change cha**et in WiFi settings - GPi Case
    retroflaggpi wifi
    • jsit
      jsit last edited by jsit
      I have a Retroflag GPi Case with a Raspberry Pi Zero W running Recalbox 9.2.3-Pulstar. All the configuration is the default that gets set when first booting on a GPi.
      In Network Settings, I'm unable to "change cha**et" (character set*) to get lowercase letters. It looks like I'm supposed to use up/down for this, but those buttons don't do anything.
      Any tips? Thanks.
      * A profanity filter seems to be modifying "char-set"
      sonyc 1 Reply Last reply Reply Quote 0
      • sonyc
        sonyc @jsit last edited by
        @jsit I think I remember having to first setup the controller (assign the keys) in order for that to work.
        101.4k
