    Volume Controller w/ GPIO on Pi5?
    GamePad/GPIO/USB encoder
    volume gpio pi5
    • staycade
      staycade last edited by
      TL:DR; I am following https://wiki.recalbox.com/en/tutorials/audio/rotary-encoder-via-gpio-digital-volume-control to get a rotary encoder to work for volume, but I am not having any luck. Is there any difference I am missing with the pi5 which is causing the issue?
      theo_testperson 1 Reply Last reply Reply Quote 0
      • theo_testperson
        theo_testperson @staycade last edited by
        @staycade The old RPi.GPIO library no longer seems to work on the Raspberry Pi 5. Unfortunately, recalbox has not yet installed the alternative libraries and manual installation is not possible either. If the gpiozero library were available, you could use it to control the GPIOs and then the scripts would work again if you adapted them to the other library.
