    Can't disable RGB dual
    cant disable rgb dual
    • arielj
      arielj last edited by
      Hi !,
      I was chekcing the configuration, I have a Raspb 4+ hooked up to a CRT TV via composite cables.
      I messed up the configuration and activate RGB Dual mode.
      Now the screen is all off set to the left and all other options are not there any more.
      I want to have it the way before activation RGB Dual mode.
      I tried factory reset, but after booting, there's only RGB dual mode.
      How to go back to having RGB dual mode disabled ? (it used to say "NONE" before).
      Thanks!!!
      arielj 1 Reply Last reply Reply Quote 0
      • arielj
        arielj @arielj last edited by
        @arielj On "CRT Adapter" menu, there's only RGB Dual option now... where's before activating it, it displayed about 4 other options, including "NONE".
        How to get the other options back again? and / or disable RGB dual ?
        thanks !
