    Raspberry pi 5 bluetooth controller non responsive - issues/problems
    GamePad/GPIO/USB encoder
    bluetooth non responsive issuesproblems
    • feralshadow
      feralshadow last edited by
      I made this thread because I cannot find anything recent in the bluetooth issues with RPI 5.
      I have had the same issues with multiple bluetooth controllers on two different raspberry pi 5's.
      The Issue: The controllers are only intermittently responsive on bluetooth connection. This does get worse from range, but this is an issue from .5 meter to 3 meters in direct line of sight of the Pi 5.
      Additional info: I have tested this on 2 different pi 5's. One with a metal case and one with a plastic case. There was not noticable different between the two performance wise.
      The controllers tested were: 2x ps3, 2x ps4, 1x 3rd party switch pro compatible
      Same results on NES, SNES, GENESIS, and Dreamcast games.
      This is a recalbox copy from the official pi imager with no customizations. All filters, smoothing or post-processing has been turned off from the menu.
      If there is a thread that exists that has a solution, please let me know and I will delete this thread.
      Scavy 2 Replies Last reply Reply Quote 0
        Scavy Global moderator @feralshadow last edited by
        Hello @feralshadow, thanx 4 your feedback.
        Your case has been reported to devs.
          Re @feralshadow
          It was a known bug on Pi5, devs brought a lot of modifications after the release of the experimental pi5 version. Beta-testers are on the way.
