    Duckstation at 240p
    Your recalbox
    duckstation 240 crt
    • BruteIRUKaNDJi
      BruteIRUKaNDJi last edited by
      Hi all,
      Is there a reason the duckstation emulator disappears when using 240p mode for Recalbox? I set up a fresh card this afternoon and when plugged in to my 1080p TV its there and configurable but when I change to 240p mode and plug into my CRT TV the emulator is no longer selectable. Does the core not support 240? A d**n shame if not.
      betty4920taylor 1 Reply Last reply Reply Quote 0
      • betty4920taylor
        betty4920taylor @BruteIRUKaNDJi last edited by
        Hello Catlikesbest@BruteIRUKaNDJi,
        It appears that you’re encountering an issue with the DuckStation emulator when using 240p mode on Recalbox.
        When switching to 240p mode and connecting to your CRT TV, the DuckStation emulator might not be compatible with this specific resolution.
        Ensure that you’ve followed all the instructions correctly for setting up 240p mode. You can refer to the Recalbox tutorial on configuring CRT screens with composite video.
        Make sure your CRT TV supports 240p resolution and that the video settings are correctly configured.
        DuckStation allows manual configuration adjustments through its configuration files.
        You can edit these files manually to tailor the emulator settings to your specific needs.
        Additionally, consider creating a configuration override file to fine-tune the emulator behavior. You can find more information on configuration overrides in the Recalbox documentation.
        Best Regards,
        lucyy300 1 Reply Last reply Reply Quote 0
        • lucyy300
          lucyy300 @betty4920taylor last edited by Pitch64
          @betty4920taylor said in Duckstation at 240p:
          Make sure your CRT TV supports 240p resolution.
