    Add to FAQ
    faq x8664
    • miguel-mayol
      miguel-mayol last edited by
      An X86_64 version, snap, flatpack or metapackage, or at least being able to copy/paste the config files? I like emulators,  I love your project. I use Manjaro I tried to install the packages and it is hard to configure not because it is difficult, but because it needs patience to configure it all line by line instead of a GUI where to set the paths, or even better where to set the root path and then put there the directories or links So a meta package at AUR (deb rpm) with your default configurations, or a more modern approach with snap  and or flatpack packages would be appreciated, and if I can help I would gladly do so.
      100.7k
