    8BitDo Ultimate C 2.4G
    GamePad/GPIO/USB encoder
    8bitdo ultimate 2.4g
    • Miga
      Miga last edited by
      I am unable to connect my 8BitDo Ultimate C 2.4G using the usb dongle on my Recalbox 9.1 😞
      Is there something I can do?
      LefternHempfield 1 Reply Last reply Reply Quote 0
      • LefternHempfield
        LefternHempfield @Miga last edited by
        @Miga Are you using a USB 3.0 port or USB 2.1? I've had radio interference with the USB 3.0 ports before (on my PC) and it screwed with my wireless mouse and keyboard pretty bad. The fix I used (when I had no other options but a USB 3.0 port) is to use a USB 2.1 hub that's on a cable that moves the dongle physically away from the USB 3.0 port itself, and that seems to work.
