    More ROMs with 2nd volume?
    more roms 2nd volume
    • bambou51
      bambou51 last edited by
      I bought an arcade cabinet and it has been delivered with a Raspberry Pie 4 running recallbox on a 128GB SD card.
      The card is basically full, and I want to add more systems and rooms.
      As I'm not really tech savvy my 1st question is, if it's possible to add a 2nd volume that will contain ROMs either using a USB dongle or an external hard drive connected by USB? That would be for me the easiest solution. That way I can keep all the existing and just add new games and systems without having to touch the current SD card. The other solution would be to use a lager SD card, but to do so, I will need to clone the current one, but also at the same time increase the ROM partition size and I'm not really sure how to do this.
      Is the 1st solution possible (just add a new volume that will add game to the existing list) and if not, what are the steps to clone the sd card while also increasing the partition size? BTW I have a Windows computer to do this DS card work.
      Thanks!
      M__a__a__x 1 Reply Last reply Reply Quote 0
      • M__a__a__x
        M__a__a__x Global moderator @bambou51 last edited by
        @bambou51
        Hi,
        Yes it is entirely possible and very easy. Here is a video link of a tutorial :
        https://www.youtube.com/watch?v=3OJiyK0sXH0
        It is in French but you can put the subtitles and their translations automatically.
        If necessary, do not hesitate to ask your questions.
        Did we answer your question?
        Sincerely
        For the Recalbox team, Maax
        Oui, c'est tout à fait possible et très simple. Voici un lien vidéo d'un tutoriel :
        Il est en français mais vous pouvez mettre les sous-titres et leurs traductions automatiquement.
        Si nécessaire, n'hésitez pas à poser vos questions.
        Recalboxment votre,
        M__a__a__x
