    Phillips CD-i Emulation Broken On Pi 5
    Emulator Arcade/PC/Console
    phillips cd-i broken
    • HGYADgs
      HGYADgs last edited by HGYADgs
      Board model: Pi 5 (8GB)
      Recalbox version (build): 9.2
      Hardware (Micro SD, Power Supply, etc.): Pi 5 (8GB), Samsung Pro Ultimate 128GB SD card, official Pi 5 USB-C Power Supply, official Pi 5 Micro HDMI to HDMI Cable
      Controller(s): Xbox 360 Wireless
      Hello everyone. I currently have a Pi 4 running Recalbox 9.1 and was lucky enough to recently purchase a Pi 5. So I installed Recalbox 9.2 on the Pi 5 and transferred over the same BIOS/ROM files.
      Most systems are working ok but it appears Philips CD-i emulation is totally broken and crashes the Pi 5. None of my 3 games (Burn Cycle, Hotel Mario, The Apprentice) work properly and launching any CD-i game results in the correct bezel on the sides but a black screen in the middle with no controller input available so I have to pull the power cable to shut down the Pi 5. There is only 1 CD-i emulator (Libretro CDI2015) available for the Pi so I am unable to test with another emulator. All BIOS files are green/matching MD5 and the same ROMs are working fine with the same emulator on Pi 4/Recalbox 9.1.
      I've also noticed on the Pi 5 that the "Last Played" toggle/section doesn't stay "Off". I turn off the setting via Start button -> Advanced Settings -> Virtual Systems -> Show Last Played System -> Set to "Off". But after launching a game and going back to Emulation Station, the "Last Played" section is populated (even though the above toggle still shows "Off").
      HGYADgs 1 Reply Last reply Reply Quote 0
      • HGYADgs
        HGYADgs @HGYADgs last edited by HGYADgs
        Also I forgot to add the game ROMs are .chd files (the wiki states the Libretro-cdi2015 emulator only supports .chd and .cmd extensions).
        I even took the original game files from the .zip and ran them through the current CHDMAN executable (0.261) to re-create the .chd files and make sure they are up to date...but I am still having the same issue.
