    Fat header bar
    fat header bar
    • betlog-betlog
      betlog-betlog last edited by
      Probably not the best way to make a first post, but it's certainly the first thing I noticed. The amount of screen that the forum header bar consumes is a little excessive. Even after it partially retracts it's disproportionately large. Admittedly I have my fonts enlarged somewhat for the 55" TV I use as monitor, so I'm probably not the typical viewer... But I though it should be mentioned. I keep ducking my head to try and see under the d**n bar. 🙂
      100.6k
