    Permanently disable turbo.
    Your recalbox
    mgba gameboy turbo
    • alexf
      alexf last edited by
      Hi friends,
      Apologies if this isn't the right place for this, I'm new to the forum. Anyways, I used mGBA to play gameboy games. I'm using recalbox on my GPi Case 2. The quicksave/load buttons are mapped to X & Y, which are also the turbo A & B buttons in the mgba config.
      I go into the mGBA menu and disable the turbo buttons, but the change doesn't persist after I exit the game. I've looked at the Libretro mGBA wiki page, but it doesn't list options to set/disable buttons in the cfg file.
      I'd appreciate any thoughts on how I can permanently disable turbo for roms played with mGBA. TIA.
      poppadum 1 Reply Last reply Reply Quote 0
      • poppadum
        poppadum @alexf last edited by
        @alexf It seems to work for me if I go into the Retroarch menu (hotkey+B), then the Controls menu, edit the controls, then Save Content Directory Remap file.
        That creates the file /recalbox/share/system/.config/retroarch/config/remaps/mGBA/gba.rmp which is autoloaded whenever I start a game in the roms/gba/ directory.
        According to the docs it's supposed to be possible to create an override file in roms/gba/.retroarch.cfg but I've never been able to get it to work.
