    Sync drop rgb dual
    sync drop rgb dual
    • lostcause412
      lostcause412 last edited by
      I've had the rgb dual for around 8 months it's worked great. Recently the sync started dropping, sometimes it takes a few seconds and will come back but now nothing. All other systems in my setup still work fine. I'm going to a scart switcher then to a extron crosspoint, then into my pvm. I went straight from the rgb dual to my pvm, that didn't make a difference. Any help would be appreciated. Thanks.
        Scavy Global moderator @lostcause412 last edited by
        @lostcause412 hello
        i suggest you join the discord on the RGBDual thread.
        Ask for @digitaLumberjack or @Bkg2k
