    GPi Case 2 - Screen stays black on V > 8.0
    gpi case stays 8.0
    • scesoft
      scesoft last edited by
      Hi all,
      I exchanged my CM4 Module with EMMC to a CM4 Lite.
      Wanted to use the SD Card slot and now finally after 1 1/2 years i got a CM4 lite.
      1. attempt:
        I flashed Recalbox 8.0 to SD Card and installed the Display patch.
        Hurray -> Recalbox booted and i could configure it on the GPi 2 screen.
      2. attempt (now it gets ugly):
        I flashed Recalbox 9.1 to SD Card and DID NOT INSTALL the Display patch (regarding documentation not needed).
        Inserted SD to GPi 2 -> Nothing 😞 -> stays black
      3. attempt:
        I flashed Recalboc 8.0 again and configured it.
        Then it updated to Recalbox 8.1.1
        Reboot
        Screen stays black 😞 😞
      I have no clue what to do now 😞
      Wanted to change to recalbox, but can't get it working.
      Retropie works.
      Recalbox Version < 8.1 works.
      CM4 Module is placed OK (Retropie and older Recalbox works)
      Ahhh - I have no Dock so i can't test anything via HDMI 😞
      Recalbox is definitely booting, because a hardware.log is created on th SD card, but screen stays black/empty 😞
      Does anbody have a tipp what i'm doing wrong?
      kind regards,
      Peter
      100.3k
