    8bitdo Ultimate Bluetooth controller
    GamePad/GPIO/USB encoder
    8bitdo ultimate bluetooth
    • Ewok
      Ewok last edited by
      8bitdo Ultimate Bluetooth controller doesn't work Recalbox 9.1 on Pi4
      I can pair it but the buttons sometimes work, sometimes they don't, I can't even assign buttons for control. I checked it on Steam Deck and Mac, everything works perfectly. Maybe there is no support from Recalbox yet?
        Scavy Global moderator @Ewok last edited by
        @Ewok hi,
        i'm reporting your case to the team, we're working on pads compatibility
        • Walki
          Walki last edited by
          Are there and News regarding the Type of Controller? I have Problems to pair the Controller. Sometimes After pairing the Buttons are still not useable. Sometimes the pairing gets lost.
          Can I help in anyway to get the Controller running? It is a very good and affordable controller and should be running.
          After pairing the controller is detected as a pro controller.
          There are no Problems if the controller is connected by cable.
