    Recalbox RGB Dual
    Your recalbox
    recalbox rgb dual
    • desktopdynamite
      desktopdynamite last edited by
      Hello, first post here.
      I have ordered the Recalbox RGB dual and it's on it's way. I also have the RGB-Pi which is in use with a Rpi 4 8GB with a Sony 29" CRT TV monitor.
      The reason that I have bought the Dual is to be able to hook my spare Rpi 400 with a 20" LaCie Electron 22 blue II CRT via VGA.
      My query is that I see most of the videos on youtube in French, and have not seen any reviews in English language.
      Also, for RGB-Pi there is a dedicated telegram channel for downloading related stuff, is there also the same for Recalbox RGB Dual ? Or perhaps on Discord, although am not familiar with using Discord TBH.
      I have downloaded the Recalbox OS to be used with my Rpi400, next, should I put the ROMs, BIOS packs etc on a seperate USB SD or SSD ?
      Any help is appreciated.
      Thanks in advance!
      • dordle12
        dordle12 Banned last edited by
        This post is deleted!
        100.8k
