    9.1 - Stuck on a black screen on CRT TV using component cable
    crt rpi3b+ component black screen issue
    • pslawx
      pslawx last edited by
      Hello, I would like to use recalbox on a CRT TV using component cable, I followed since the basic configuration on Recalbox documentation website but I got stuck on this black screen
      I tried different configurations and even stock configuration with a clean recalbox installation without NOOBs dual boot, but the situation is the same, follow my configuration files
      config.txt
      # Boot loader configuration                                                #
      # Warning: do not edit this file as it will be overwritten when upgrading! #
      # Using /etc/modules is deprecated and no longer supported on 4.4 kernel
      # So manually enable audio
      dtparam=audio=on
      # if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or
      # give a low resolution because tv had no enough time to initialize it
      boot_delay=3
      # disable boot rainbow
      disable_splash=0
      # default CEC name
      cec_osd_name=recalbox
      avoid_safe_mode=1
      kernel=boot/linux
      initramfs boot/initrd.gz
      # force hdmi while the tv can take time before sending the signal on the hdmi output
      hdmi_force_hotplug=0
      # total amount of GPU memory
      #gpu_mem=128
      # your settings can be set in /boot/recalbox-user-config.txt
      include recalbox-user-config.txt
      # overclocking settings are automatically managed in this file
      # do not remove this line, nor edit the file
      include recalbox-oc-config.txt
      # Raise the first security limit up to 70° instead of 60° for pi3 and pi4
      #[pi3]
      #temp_soft_limit=70
      #dtoverlay=vc4-kms-v3d
      #include crt/recalbox-crt-config.txt
      #[pi4]
      #arm_64bit=0
      #temp_soft_limit=70
      #dtoverlay=vc4-kms-v3d,cma-512
      #dtoverlay=rpivid-v4l2
      #hdmi_enable_4kp60=1
      #[board-type=0x12]
      # custom config
      [all]
      # Change to your needs
      # uncomment if you get no picture on HDMI for a default "safe" mode
      #hdmi_safe=1
      disable_overscan=0
      # uncomment to force a specific HDMI mode (this will force VGA)
      #hdmi_group=1
      #hdmi_mode=1
      # Sound output. Set to 0 or comment for autodetect, 1 for DVI, 2 to force HDMI.
      #hdmi_drive=2
      #config_hdmi_boost=0
      # uncomment for composite PAL
      hdmi_ignore_hotplug=1
      enable_tvout=1
      sdtv_mode=0
      sdtv_aspect=1
      sdtv_disable_colourburst=0
      audio_pwm_mode=2
      gpu_mem_256=128
      gpu_mem_512=256
      gpu_mem_1024=448
      # uncomment for lirc-rpi
      #dtoverlay=lirc-rpi
      # uncomment if you have chinese TV display and display is garbled or slow
      #hdmi_ignore_edid=0xa5000080
      #disable 4k
      hdmi_pixel_freq_limit:0=200000000
      hdmi_pixel_freq_limit:1=200000000
      overscan_scale=1
      temp_soft_limit=70
      cmdline.txt
      dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.sync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 consoleblank=0 loglevel=3 elevator=deadline vt.global_cursor_default=0 logo.nologo splash label=RECALBOX video=Composite-1:720x480@60i rootwait fastboot noswap
      recalbox.conf
      # System Variable
      ;system.power.switch=ATX_RASPI_R2_6      # https://lowpowerlab.com/guide/atxraspi/#installation
      ;system.power.switch=MAUSBERRY           # https://www.mausberrycircuits.com/pages/setup
      ;system.power.switch=REMOTEPIBOARD_2003  # https://www.msldigital.com/pages/support-for-remotepi-board-2013
      ;system.power.switch=REMOTEPIBOARD_2005  # https://www.msldigital.com/pages/support-for-remotepi-board-plus-2015
      ;system.power.switch=WITTYPI             # https://www.uugear.com/witty-pi-realtime-clock-power-management-for-raspberry-pi
      ;system.power.switch=PIN56ONOFF          # https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
      ;system.power.switch=PIN56PUSH           # https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
      ;system.power.switch=PIN356ONOFFRESET    # https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
      ;system.power.switch=PIN356PUSHRESET     # https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
      ## fbcp FrameBuffer Copy Program
      ## For small TFT screen on GPIO and SPI
      ## See https://github.com/recalbox/recalbox-os/wiki/Utility---Use-of-fbcp-for-small-TFT-screen-%28EN%29 for details
      ## Needed for Waveshare 3.2" 3.5" TFT screen, 2.8" Adafruit screen
      ## See https://wiki.recalbox.com/en/tutorials/video/tft/tft-lcd-on-spi-bus
      ## for support and configuration details needed by /boot/config.txt
      system.fbcp.enabled=0
      ## Splash screen duration
      ##  0 : Video will be stopped when emulationstation is ready to start.
      ## -1 : All the video will be played before emulationstation start (default)
      ## >0 : Time the video will be played before emulationstation start (in seconds)
      system.splash.length=-1
      ## Splash videos selection
      ## all: select a boot video in recalbox videos and user videos
      ## recalbox: select a boot video only in recalbox videos
      ## custom: select a boot video only in user videos
      ## Any invalid value means "all"
      system.splash.select=all
      system.manager.enabled=1
      ## Currently, only version 2 is available
      system.manager.version=2
      ## Recalbox API (REST)
      system.api.enabled=0
      ## Allow a specific resolution for ES only from the command : tvservice -m [MODE]
      ## Leave commented for the default usual behaviour
      system.es.videomode=720x400
      ## EmulationStation
      ### menu style
      ### default -> default all options menu
      ### none -> no menu except the game search menu
      ### bartop -> less menu, only needed for bartops
      emulationstation.menu=default
      ### Select a system to show on boot (use rom directory name) (string)
      emulationstation.selectedsystem=favorites
      ### Show the gamelist of the first or selected system on boot (0,1)
      emulationstation.bootongamelist=0
      ### Disable system view. ES will boot and show ONLY the first or selected system (0,1)
      emulationstation.hidesystemview=0
      ### Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
      emulationstation.gamelistonly=0
      ### Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
      emulationstation.forcebasicgamelistview=0
      ### Filter out adult games
      ### you may use emulationstation.snes.filteradultgames=1
      ### to filter out adult games for the snes system or any other system
      ;emulationstation.filteradultgames=1
      ### Zipped gamelist preference
      ### Whatever you choose, emulationstation can read both compressed
      ### and uncompressed gamelist.xml or gamelist.zip
      ### However updated gamelist will be saved in your prefered format.
      ### Zipped format may save load time, especially on slow devices.
      ### 0 = gamelist.xml
      ### 1 = gamelist.zip
      ;emulationstation.zippedgamelist=1
      ## Arcade metasystem
      ## Activate the Arcade metasystem to group all games from piFBA, FBN (libretro), MAME and optionally Neogeo
      ## into a single "Arcade" system.
      ;emulationstation.arcade=1
      ## You may want to specify its position in the system list. (Default: 0)
      ## Negatives values may be used to tart from the end (-1 = last position)
      ;emulationstation.arcade.position=0
      ## Include NeoGeo or not (default: 1)
      ;emulationstation.arcade.includeneogeo=1
      ## Hide included system or leave them in the system list (default: 1)
      ;emulationstation.arcade.hideoriginals=1
      ## Virtual systems
      ### Activate a virtual system with all games available from all systems
      ;emulationstation.collection.allgames=1
      ### Activate a virtual system with all multiplayer games (players >= 2)
      ;emulationstation.collection.multiplayers=1
      ### Activate a virtual system with last played games
      ;emulationstation.collection.lastplayed=1
      ## Videosnaps
      ### Delay before videosnaps start, in millisecond. Default: 2s
      ;emulationstation.videosnaps.delay=2000
      ### Video loop times. 0 = no video. 1 or more = the video loops x times before fading out
      ;emulationstation.videosnaps.loop=1
      ### Enable videosnap sound/music
      ;emulationstation.videosnaps.sound=1
      ## Scrapers
      ### Activate this option to extract region from filename when possible
      ;scraper.extractregionfromfilename=1
      ### Select the source of game's names
      ### 0 = from scrapper result (default)
      ### 1 = from filename
      ### 2 = from filename undecorated (i.e: (text) and [text] removed)
      ;scraper.getnamefrom=0
      ### ScreenScraper.fr
      ### Force media region - if not defined, region is taken from system.language. Default: us
      ;scraper.screenscraper.region=eu
      ### Force text language - if not defined, region is taken from system.language. Default: en
      ;scraper.screenscraper.language=fr
      ### Choose the media to download among:
      ### screenshot: game screenshot
      ### title     : game title screenshot
      ### box2d     : Front case
      ### box3d     : 3D rendered case
      ### mixv1     : Recalbox special mix image V1 (default)
      ### mixv2     : Recalbox special mix image V2
      ;scraper.screenscraper.media=mixv1
      ### ScreenScraper account
      ;scraper.screenscraper.user=
      ;scraper.screenscraper.password=
      ## Emulator special keys
      kodi.enabled=1
      ## Start kodi at launch (0,1)
      kodi.atstartup=0
      kodi.xbutton=0
      ## Allow a specific resolution for Kodi only from the command : tvservice -m [MODE]
      ## By default is using the default resolution of your screen
      kodi.videomode=default
      ;kodi.network.waittime=10
      ## Hyperion
      ## Hyperion allows you to use an ambilight like led system on your recalbox
      ## Use hypercon to create your configuration file, and copy it in /recalbox/share/system/configs/hyperion/hyperion.config.json
      hyperion.enabled=0
      ## Set system hostname
      system.hostname=RECALBOX
      ## Activate wifi (0,1)
      wifi.enabled=0
      ## Set wifi region
      ## More info here: https://wiki.recalbox.com/en/tutorials/network/wifi/wifi-country-code
      wifi.region=JP
      ## Wifi SSID (string)
      ;wifi.ssid=new ssid
      ## Wifi KEY (string)
      ## after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
      ## you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
      ;wifi.key=new key
      ## Wifi - static IP
      ## if you want a static IP address, you must set all 4 values (ip, netmask, gateway and nameservers)
      ## if any value is missing or all lines are commented out, it will fall back to the
      ## default of DHCP. For nameservers, you must set at least 1 nameserver.
      ;wifi.ip=manual ip address (ex: 192.168.1.2)
      ;wifi.netmask=network mask (ex: 255.255.255.0)
      ;wifi.gateway=ip address of gateway (ex: 192.168.1.1)
      ;wifi.nameservers=ip address of domain name servers, space separated (ex: 192.168.1.1 8.8.8.8)
      # secondary wifi (not configurable via the user interface)
      ;wifi2.ssid=new ssid
      ;wifi2.key=new key
      # third wifi (not configurable via the user interface)
      ;wifi3.ssid=new ssid
      ;wifi3.key=new key
      ## Samba share
      system.samba.enabled=1
      ### Virtual Gamepads
      ### SSH
      system.ssh.enabled=1
      audio.device=auto
      ## Set system volume (0..100)
      audio.volume=90
      audio.bgmusic=1
      # Enable ERTM
      controllers.bluetooth.ertm=1
      controllers.ps3.enabled=1
      ## Choose a driver between bluez, official and shanwan
      ## bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
      ## official -> sixad drivers, support official and gasia sisaxis
      ## shanwan -> shanwan drivers, support official and shanwan sisaxis
      controllers.ps3.driver=bluez
      # ------------ D2 - GPIO Controllers ------------ #
      ## GPIO Controllers
      controllers.gpio.enabled=0
      ## mk_gpio ar***ents, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
      controllers.gpio.args=map=1,2
      ## Custom mk_gpio ar***ents,
      ## controllers.gpio.args=map=5 gpio=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk  for one controller,
      ## controllers.gpio.args=map=5 gpio=pin1,pin2,pin3,.....,pin12,pin13
      ## controllers.gpio.args=map=5,6 gpio=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk gpio2=Y-,Y+,X-,X+,start,select,a,b,tr,y,x,tl,hk for 2 (map=5,map=5,6)
      ## controllers.gpio.args=map=5,6 gpio=gpiox,gpioy,gpioz,.....,gpiou,gpiov gpio2=gpiox,gpioy,gpioz,.....,gpiou,gpiov
      # where gpiox,gpioy,gpioz ... are NOT pin numbers on the connector, BUT location gpio numbered as in
      # https://www.raspberrypi-spy.co.uk/wp-content/uploads/2012/06/Raspberry-Pi-GPIO-Layout-Model-B-Plus-rotated-2700x900.png
      ## Set pin to -1 to disable it
      # controllers.gpio.args=map=5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,2 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,3
      ## MCP configuration : GPIO and MCP can be used together. You can mix them.
      ## map=0x20,0x21 for 2 mcp23017 on i2c bus
      #controllers.gpio.args=map=0x20,0x21,5,6 gpio=4,17,27,22,10,9,25,24,23,18,15,14,-1 gpio2=11,5,6,13,19,26,21,20,16,12,7,8,-1
      ## Raspberry Pi Hats
      ## Fan controllers
      ## supported boards
      ### Waveshare PoE hat (B)
      ### Argon Forty / Argon One
      ### Experimental PI PiBoy DMG
      ### Raspberry PI PoE+
      ### Pimoroni fan SHIM
      ## Enable fan management and oled info screen by setting hat.wpaf.enabled=1
      hat.wpaf.enabled=0
      ## and set the correct board name:
      ##   wspoehatb
      ##   argonforty
      ##   piboy
      ##   rpipoeplus
      ##   fanshim
      ##example hat.wpaf.board=wspoehatb
      ;hat.wpaf.board=board_name
      # ------------ D3 - Steam Controllers ------------ #
      ## Enable steam controller service
      controllers.steam.enabled=0
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 ar***ents
      controllers.db9.args=map=1
      ## Gamecon controllers
      ## Enable gamecon controllers, for nes, snes, psx (0,1)
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=1
      # ------------ D4 - Joycon Controllers ------------ #
      controllers.joycond.enabled=1
      # ------------ E - Language and keyboard ------------ #
      system.language=en_US
      ;system.kblayout=us
      ## Set you local time
      ;system.timezone=Europe/Paris
      # ------------ F - UPDATES ------------ #
      updates.enabled=1
      # Update type : default to stable
      updates.type=stable
      # ------------ G - HERE IT IS - GLOBAL EMULATOR CONFIGURATION ------------ #
      ## use 'auto' : switches to CEA 4 HDMI if supported, else keep the current resolution
      ## (string)
      global.videomode=default
      ## Shader set
      ## (none, retro, scanlines)
      global.shaderset=none
      global.integerscale=0
      global.shaders=
      global.ratio=auto
      global.smooth=1
      global.rewind=1
      global.autosave=0
      global.retroachievements=0
      global.retroachievements.hardcore=0
      global.inputdriver=auto
      ## Demo screensaver parameters
      ## Set the system list from which ES will run random games.
      ## Empty list or unexisting key means all available systems
      global.demo.systemlist=3do,amigacd32,atari2600,atari5200,atari7800,daphne,fbneo,fds,gamegear,gba,lynx,mame,mastersystem,megadrive,neogeo,nes,ngpc,pcengine,sega32x,sg1000,snes
      ## Default demo game sessions last 90s. Change this value if you want shorter or longer sessions
      ;global.demo.duration=90
      ## Default game info screen duration lasts 6s. Change this value if you want shorter or longer info screens.
      ;global.demo.infoscreenduration=6
      ## Retroarch AI Translation service
      ## Comment out or set to 0 the following key if you don't want the AI service
      global.translate=1
      ## Set the source and the target languages.
      ## Allowed language list: EN, ES, FR, IT, DE, JP, NL, CS, DA, SV, HR, KO, ZH_CN, ZH_TW, CA, BG, BN, EU, AZ, AR, SQ,
      ##                        AF, EO, ET, TL, FI, GL, KA, EL, GU, HT, IW, HI, HU, IS, ID, GA, KN, LA, LV, LT, MK, MS,
      ##                        MT, NO, FA, PL, PT, RO, RU, SR, SK, SL, SW, TA, TE, TH, TR, UK, UR, VI, CY, YI
      ## Setting the translate.from key to a specified language may speed up or give more accurate results
      ## If translate.to key is commented, the default value is extracted from system.language or, if system.language is
      ## undefined, set to auto (=EN).
      global.translate.from=auto
      global.translate.to=auto
      ## zTranslate API Key
      ## go to https://ztranslate.net and create an account.
      ## validate your account, then log in and go to the settings page
      ## Look for the API Key at the bottom of the page, then uncomment the following key and paste your API Key:
      ;global.translate.apikey=RECALBOX
      ## Other translation service
      ## If you want to use another translation service or a custom API call, use this key to
      ## specify the url to call. If the key is not empty, it is used instead of zTranslation's API Key
      ;global.translate.url=
      # ------------ H - EMULATORS CHOICES ----------- #
      ## You can override the global configurations here
      ## Here is the snes example
      ;snes.videomode=CEA 4 HDMI
      snes.core=snes9x2010
      ;snes.ratio=16/9
      ;snes.smooth=0
      ;snes.rewind=1
      ;snes.autosave=0
      ;snes.emulator=libretro
      ;snes.integerscale=0
      ## If you do not want recalboxOS to generate the configuration for the emulator:
      ## Default cores for RPi3
      c64.core=x64
      ## NeoGeo emulator
      neogeo.emulator=libretro
      ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fbneo, mame2000)
      neogeo.core=fbneo
      #n64.videomode=DMT 4 HDMI
      n64.videomode=default
      ## Dreamcast emulator
      ## Like N64, such a CPU intensive emulator needs a small resolution
      ## Consider DMT 4 HDMI (640*480) or DMT 9 HDMI (800*600). If you have a black screen on dreamcast, try DMT 9 HDMI here
      ;dreamcast.videomode=DMT 4 HDMI
      ## Include or exclude a particular system from the demo screensaver
      ## You may change the global.demo.systemlist key or include/exclude every single system
      ;snes.demo.include=0
      ## Set the session duration for a particular system
      ;snes.demo.duration=90
      ## Disable Atomisware
      atomiswave.ignore=1
      ## Disable Dosbox Pure rewind
      dos.rewind=0
      ## Megaduck emulator
      megaduck.integerscale=0
      # ------------ I - NETPLAY PARAMETERS ----------- #
      ## All these values are handled by Recalbox itself
      global.netplay=1
      global.netplay.nickname=
      global.netplay.port=55435
      global.netplay.relay=
      global.netplay.lobby=http://lobby.libretro.com/list/
      # ------------ J - TFT SECONDARY SCREEN ----------- #
      #Second miniTFT screen as marquee to display scrapes and videos
      #Enable it with system.secondMiniTFT.enabled=1, disable with system.secondMiniTFT.enabled=0
      #this configuration is REQUIRED
      system.secondminitft.enabled=0
      #Type of mini TFT : OGST, unknown
      #Most of spi tft screen are enabled thanks to overlays in /boot/config.txt in rpi and /boot/config.ini on odroidxu4
      #please check the specific configuration of your screen
      #Some examples are available on the page .....
      # values are :
      # - overlay : screen configured through overlays in /boot/config.txt or /boot/config.ini (odroidxu4/ogst)
      # - default : the rest of the world
      #this configuration is REQUIRED if system.secondminitft.enabled=1
      ;system.secondminitft.type=overlay
      #Choose the resolution of your screen
      #miniTFT resolution  320x240 -> 240p, 480x320 -> 320p
      ;system.secondminitft.resolution=240p
      #Scraped image aspect on tft screen : fbv display option
      # options available : stretch, ignore-aspect, enlarge.
      # stretch : Strech (using a simple resizing routine) the image to fit onto screen if necessary
      # alpha : use the alpha channel (if applicable)
      # ignore-aspect : Ignore the image aspect while resizing
      # enlarge : Enlarge the image to fit the whole screen if necessary
      # 1 = enabled, 0 = disabled
      ;system.secondminitft.imagestretchenabled=1
      ;system.secondminitft.imageenlargeenabled=0
      ;system.secondminitft.imagealphaenabled=0
      ;system.secondminitft.imageignoreaspectenabled=1
      #When activating the second TFT screen, you may want to display
      #game scraped video only on the second screen. This variable
      #allows you to disable scraped video playing in ES during game browsing
      #system.secondminitft.disablevideoines=1 disable video playing in ES
      #system.secondminitft.disablevideoines=0 enable video playing in ES
      #this configuration is OPTIONAL if system.secondminitft.enabled=1
      ;system.secondminitft.disablevideoines=1
      #if the backlight of your your screen can be manage by PWM,
      #indicates the  GPIO value of your PWM control
      #WiringPi and its gpio program will be used to control the backlight
      #when RB goes in SLEEP mode, and when it wakes up.
      #On raspberry pi, PWMs cannot be used simultaneously with Jack sound output.
      #If your are using HDMI or a Audio hat you can use backlight PWM control for the second screen
      #If you are using Jack output please leave commented.
      #The Screen will be switch down in Sleep mode, and switch on when it wakes up.
      #On OGST, only this mode is available.
      ;system.secondminitft.backlightcontrol=18
      # system.secondminitft.usemarquee variabla allows you to display a different
      # image during running game. just creat a directory named "marquees" in media
      # aside videos and images and put new images with the same name as in images
      # example :
      #   - /recalbox/share/roms/neogeo/media/marquees/alpham2.png
      #   - /recalbox/share/roms/neogeo/media/images/alpham2.png
      # if set to 1, in game the marquee images will be displayed
      # if set to 0, in game the scraped images will be displayed
      ;system.secondminitft.usemarquee=0
      #system.secondminitft.sleepenabled allows you to enable/disable
      #sleep mode for the second TFT. If set to 1 sleep mode is enabled and
      #backlight of the screen will be OFF. If set to 0, sleep mode is
      #disabled and the backlight of the screen will be always On
      ;system.secondminitft.sleepenabled=0
      # Ignore 240ptestsuite system until crt is turned on
      240ptestsuite.ignore=1
      emulationstation.theme.recalbox-next.colorset=1-light blue colors
      emulationstation.theme.recalbox-next.gameclipview=0 - DEFAULT
      emulationstation.theme.recalbox-next.gamelistview=1-standard gamelist
      emulationstation.theme.recalbox-next.region=us
      emulationstation.theme.recalbox-next.iconset=1-standard icons
      emulationstation.theme.recalbox-next.menuset=1-light blue icons
      emulationstation.theme.recalbox-next.systemview=1-vertical left
      system.overscan=0
      system.firsttimeuse=0
      I tested my cable with raspbian OS and it worked, it also worked with emustation being compiled directly on raspbian OS.
      I saw the same situation on forum with other people in older versions, not found a resolution there.
      Thank you in advance for any help 🙂
      100.8k
