    /overlay folder read-only problem despite mounting it to write mode ?!
    overlay write readonly mount error
    • eightkiller
      eightkiller last edited by
      Hi, I usually have no problem mouting / or /boot partitions to be able to write or add or replace some files inside (with mount -o remount,rw / for example), but I wanted to do the same with the /overlay folder (mount -o remount,rw /overlay), the command seems to work, but impossible to replace things, it is still in read-only mode. What should I do to be able to do so ? The folder seems to work differently.
      Thanks in advance for your help 🙂
