    Recalbox does not like generic gamepads
    GamePad/GPIO/USB encoder
    gamepad mappings usb dinput
    • jack-mcslay
      jack-mcslay last edited by
      I have a pair of saturn-like gamepads I wanted to use in it but the funcionality is all over the place, often times trying to use them the mapping in the game is completely different to the point I can't even exit the game and have to SSH to the unit to reboot it.
      As far as I can tell it's dInput based. The output of lsusb is as follows:
      Bus 001 Device 004: ID 0810:e501 Personal Communication Systems, Inc. SNES Gamepad
      Device Descriptor:
        bLength                18
        bDescriptorType         1
        bcdUSB               1.00
        bDeviceClass            0
        bDeviceSubClass         0
        bDeviceProtocol         0
        bMaxPacketSize0         8
        idVendor           0x0810 Personal Communication Systems, Inc.
        idProduct          0xe501 SNES Gamepad
        bcdDevice            1.06
        iManufacturer           0
        iProduct                2 usb gamepad
        iSerial                 0
        bNumConfigurations      1
        Configuration Descriptor:
          bLength                 9
          bDescriptorType         2
          wTotalLength       0x0022
          bNumInterfaces          1
          bConfigurationValue     1
          iConfiguration          0
          bmAttributes         0x80
            (Bus Powered)
          MaxPower              500mA
          Interface Descriptor:
            bLength                 9
            bDescriptorType         4
            bInterfaceNumber        0
            bAlternateSetting       0
            bNumEndpoints           1
            bInterfaceClass         3 Human Interface Device
            bInterfaceSubClass      0
            bInterfaceProtocol      0
            iInterface              0
              HID Device Descriptor:
                bLength                 9
                bDescriptorType        33
                bcdHID               1.10
                bCountryCode           33 US
                bNumDescriptors         1
                bDescriptorType        34 Report
                wDescriptorLength      89
               Report Descriptors:
                 ** UNAVAILABLE **
            Endpoint Descriptor:
              bLength                 7
              bDescriptorType         5
              bEndpointAddress     0x81  EP 1 IN
              bmAttributes            3
                Transfer Type            Interrupt
                Synch Type               None
                Usage Type               Data
              wMaxPacketSize     0x0008  1x 8 bytes
              bInterval              10
      Device Status:     0x0000
        (Bus Powered)
      • Damião
        Damião last edited by
        Hello,
        Unfortunately it's not surprising you have an issue with a generic controller.
        Recalbox can't support all controllers and generic controllers work randomly.
        You must check if your pad is described bellow, but my reco would be selling your generic pads to buy supported ones..
        https://wiki.recalbox.com/en/hardware-compatibility/compatible-devices/controllers
        Damião
        Recalbox 9.1 + NUC7I7BNH + SSD 2To
        2 Xbox Series Controllers + Wireless adapter
