    Compilation for rpi3
    rpi3 build comp
    • loula
      loula last edited by
      Hi Folks, I'm following the these instructions for RPI3 and it seems that the recall-box is not creating the 'recalboxOS-rpi3' files, only the rpi1 and rpi2. All other steps are working fine, I just figure out this when I was copying the files to create the SD card image as described on step C. Can I create the SD card using the 'recalboxOS-rpi2' or something is wrong with the procedure? Best Regards,
