    DOSBox keymapper not working
    Emulator Arcade/PC/Console
    dosbox keymapper error
    • FedeKrum
      FedeKrum last edited by
      Hi
      I have been using DOSBox on my Mac and when I try to make a keymap by pressing ALT-F1, I get to the following screen :
      With it, I can re-map joystick events as key pressings.
      The problem comes when I do the same on DOSBox on Recalbox.
      I get the following screen and cannot exit it as the exit button is not visible.
      My conf file on that specific ROM is this:
      https://pastebin.com/raw/pEdhHqWQ
      Any idea on how to fix this issue?
      Thanks
      midiwidi 1 Reply Last reply Reply Quote 0
      • midiwidi
        midiwidi @FedeKrum last edited by midiwidi
        @FedeKrum you posted that question a fair while ago. I have exactly the same problem. Have you found any solution?
        I remember that the keymapper worked flawlessly in earlier versions of Recalbox.
