    Is there a size limit for a micro sd cards with the GPI Case
    size limit cards gpi case
    • Snake S71
      Snake S71 last edited by
      I tried installing Recalbox on my GPI case's Raspberry Pi 0 W. I can't run any of the preloaded games and there is no share folder. When I reboot the system I get the "installing GPI case" screen and creating share folder screen.
      I heard the size of the micro sd card may be an issue. I'm using a 256GB card. Here's a link to the specific one I'm using:
      https://www.amazon.com/dp/B07S5T7YR5?ref=ppx_yo2ov_dt_b_product_details&th=1
      Is it just too large? Why exactly would it matter?
        Scavy Global moderator @Snake S71 last edited by
        @Snake-S71 hi
        There is no problem with a 256 Go card.
        But i suggest you use a A1 class 10 card, like a SanDisk.
