    PSX Rom Problems
    psx rom
    38057
    • likeafish
      likeafish last edited by
      I might be being stupid, but I'm really struggling getting any PSX roms to work. What file formats and sizes does recalbox support? What websites are people using for roms? Or can't that be discussed here? Please help! I want to play Crash Bandicoot and Tekken! Cheers, Tom.
      • loak
        loak last edited by
        Hello Tom, First question : Do you have uploaded some bios files into the /share/bios/ folder of Recalbox ? PSX need one. Here are some explanations : https://github.com/recalbox/recalbox-os/wiki/Add-system-bios-%28EN%29 For your second question, everything is in the /share/roms/psx/Readme.txt file To do all this, you can access your Recalbox by the network.
        Recalbox last update
          voljega Banned last edited by
          ... but you will need to copy your psx roms with winscp if you're on windows because it's often failing for those through the network
          colking 1 Reply Last reply Reply Quote 0
          • likeafish
            Thanks for your help guys. previously installed the bios. I've got my bin/cue files for the games I want. Is there a way to copy directly onto the SD card in Ubuntu? It's not working over network for some reason. Might see if I can run Winscp through Wine.
            • loak
              loak last edited by
              Big files, as the .bin file of a psx game, can't be uploaded through the web interface of Recalbox, but if you navigate your network with nautilus in Ubuntu you should find  your Recalbox with a /share folder. /roms folder is inside.
              • likeafish
                Amazing! Sorted!
                • colking
                  colking @voljega last edited by
                  @voljega said in PSX Rom Problems:
                  winscp
                  Hey, I uploaded some psx games using winscp but having no luck. Have you had success with this method? The psx roms i have are .iso which should work..
                  thanks
                  seic 1 Reply Last reply Reply Quote 0
                  • seic
                    seic @colking last edited by
                    @colking
                    Convert you .iso to .PBP via PSX2PSP (works also with .bin). Make the game files smaller you can also combine multi disc games to one file.
                    WinSCP is okish for smaller roms like snes but i got always probs with big flies for the psx too. Best way for transfer is still direct via your home network.
