    Metal Slug 4, 5 & 6 not working
    metal slug
    • timporteruk
      timporteruk last edited by
      Hi guys, Just curious to know if anyone has gotten Metal Slug 4, 5 and 6 to work? I've had no issues with 1, 2, 3 and X but I just can't get the rest to work. I've tried the 0.78 romset and the FBA 0.167 romset and still no joy, I have the bios files in both the bios and rom folders as well. I'm running 4.0 beta 3 using a Pi 3. Any ideas? Many thanks.
        voljega Banned last edited by
        4 & 5 works fine for me on FBA_libretro. No idea for the non working on your side, do you have the right neogeo.zio from the related romset ? 6 in mame/fba is a false one anyway it's a bootleg of the 3rd, the real 6 is on Atomiswave, an arcade system not emulated by mame but near perfectly supported by Demul... on PC only.
        • timporteruk
          Many thanks for the info, much appreciated. I think I have the neogeo.zip related to the 0.78 romset for mame, so that's likely causing the issue. Cheers.
