    XBOX 360 wireless controllers work but keep flashing
    GamePad/GPIO/USB encoder
    ecran flashing
    • marctv
      marctv last edited by
      Hi! Thank you for making RetroPie usable by developing RecalBox. Thank you so much! The plug & play promise works! There is only one tiny problem which is by all means only a minor problem. All XBOX 360 controllers connected to my windows USB connector work out of the box. But they are flashing all the time. Is there any way to get rid of this? Thank you!
      https://t.co/M2EAo6yzyk
        https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN) disable PS3 driver :
        controllers.ps3.enabled=0
        ## Choose an driver beetween official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
        Then enable xboxdrv driver :
        controllers.xboxdrv.enabled=1
        And reboot.
        • marctv
          Thank you so much. Worked instantaneously. 😃
