    Bug in CRT mode (Pi3)
    crt mode pi3
    • Wallbanger
      Wallbanger last edited by
      Hi, there is a bug in CRT mode. Using a Pi3+ with pi2scart. In CRT mode you can not switch between cores. Under "game options" normal you can chose witch core you want use for each Game. This feature is missing in Crt mode. Example. I want play Diddy Kong Racing, press start for Option, edit game. run with. Its only liberte parallel_n64 (default) normal you can switch the cores but its not shown up in Crt usage. Is there a way to fix it? It´s not only N64 all Systems running with default liberte core. Most Systems running well with default... Hope someone can fix tis bug? In HDMI mode all working well and in the core selection menü all cores shown up Its only in CRT mode. My suspicion was maybe the Theme. Used outher theme the same. core selection is not shown up.
      100.7k
