    [Solved]Saving states on FBA and Neogeo
    Emulator Arcade/PC/Console
    [solved]saving fba neogeo
    • dediz
      dediz last edited by
      Hello Guys! Is there a way to save states on FBA and Neogeo emulators? if I press "hotkey" (plus X or Y), the emulator goes to Rom config (on FBA) or unibios menu (on Neogeo)... Because the "hotkey"..... 馃槥 S贸 I cannot operate save states on this emulators. could you help me? thanks Andre
        your hotkey is mapped on which button ? if it is the same thant dip switch menu in FBA, remap your controller and affect hotkey to an other button.
        • dediz
          I remapped the hotkey from R3 To L3 and it worked! thank you!
          Copyright 漏 2021 recalbox.com
