    Second controller not working
    Emulator Arcade/PC/Console
    second
    • DejanTrpcevski
      DejanTrpcevski last edited by
      Running Recalbox 8.1.1-Electron on Raspberry Pi 3. One PS4 controller and one Shawan (PS3 clone). Both using USB cable. Both configured through the normal menu. No files or any tinkering has been done. Only uploaded the Amiga bios and a few WHDload games. Both controllers work perfectly in the emulation station interface.
      But when I launch an Amiga game in whdload format only one controller works in the game. The other controller is dead and does not respond to key presses.
      How can I get the second controller functioning?
      Related: how do I switch between mouse, keyboard and the two controllers when playing games that need different input devices?
        Scavy Global moderator @DejanTrpcevski last edited by
        @DejanTrpcevski hi which core do you use ? Did your try to set up the second pad in the core menu ?
        DejanTrpcevski 2 Replies Last reply Reply Quote 0
        • DejanTrpcevski
          DejanTrpcevski @Scavy last edited by
          @Scavy Hi thanks for the help. I found out that opening the amiberry setup while in-game (F12 i think) I could set the correct input devices for the game, and both joystick would work. But when exiting and opening the game again it would forget my settings.
          I looked into a million things and finally found some help in the amiberry release notes. It mentioned that auto switch of input is enabled by default in version 5.X.
          I compiled the newest amiberry (version 5.4) from source and this version does support auto switch of input between mouse and joystick. This is enabled by default. So everything works great now.
          However I am still interested in knowing how to configure amiberry more permanently, so that it does not forget any settings that I make in the amiberry setup menu.
          Right now everything just goes back to default settings when I open a new game. But at least, the default settings in version 5.4 work well for me now.
          I am reading the amiberry website for more info. But it would be nice to get more about how to preserve my amiberry configuration between games in the vanilla recalbox setup.
          • DejanTrpcevski
            @Scavy both controllers work fine in emulation station. I am not sure about the "core" but I am using amiberry to emulate the Amiga games.
