    neo geo games not working?
    Emulator Arcade/PC/Console
    neo geo
    6132
    • capfindus
      capfindus last edited by capfindus
      Hi guys,
      I've just take my box that was inactive for 2/3 years, update recalbox from version 6 to 8... seems everything works fine but neo geo games... I used to play them with mame emulator, now they don't work anymore, and I can't see a specific neo geo emulator in the home page...
      suggestions?
      Thanks
      • Alvin
        Alvin Banned @capfindus last edited by
        @capfindus
        Don't know what your Problem is !
        (Why did always nobody look at the RecalBox Wiki - https://wiki.recalbox.com/en/home ?)
        https://wiki.recalbox.com/en/emulators/consoles/neo-geo
        https://wiki.recalbox.com/en/emulators/consoles/neo-geo-cd
        • capfindus
          ok I'll try to be clearer...
          I can not play neo geo games... I'm using mame, tried different cores, put the infamous neogeo.zip file in every folder... still can't play those games, others run fine...
          Recalbox last version.
          Any suggestions?
          Thanks
          Alvin mattmame 2 Replies Last reply Reply Quote -1
          • Alvin
            @capfindus
            https://wiki.recalbox.com/en/emulators/arcade/mame
            • zetof
              zetof last edited by
              Hi,
              1 Find a FBNeo 1.0.0.03 RomSet
              2 Put NeoGeo Games (with neogeo.zip) into directory "/recalbox/share/roms/neogeo"
              3 Use default Recalbox NeoGeo emulator (which is FBneo)
              4 Play !
              Zetof
              • mattmame
                mattmame @capfindus last edited by
                @capfindus
                Put files in fbneo folder instead of fba folder ?
                Si vous avez aimé mon post ou s’il a pu vous aider, mettez moi une petite flèche vers le haut.
                  Scavy Global moderator @mattmame last edited by
                  @mattmame hello
                  fba is no more developped. The fba folder has disapeared it is replaced by fbneo : FinalBurn Neo
                  mattmame 1 Reply Last reply Reply Quote 0
                  • mattmame
                    mattmame @Scavy last edited by
                    @Scavy
                    That’s what I’m trying to explain.
                    Thanks
