    Theme and Intro Recalbox
    theme
    • wilson-jr
      wilson-jr last edited by
      Hello. I have two questions: - 1st Theme Edition. - 2nd Change introduction of recalbox.   1 I wonder if I myself create a theme or edit the image that subjects the Recalbox? The Recalbox is released or blocks change issues? It has a tutorial on how to change, edit, dimensions ...?   2. When you start Recalbox has the intro Recalbox. It is to change this intro? Do you have any tutorial showing how?   Thank you very much.
      • abunille
        abunille last edited by
        Hi, in RB 4 Beta 3 there is a brand new Theme. Only for information. Get root access ( https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN) ) Location of the "Themes" folder is  --> recalbox/share_init/system/.emulationstation/themes There you can put other Themes or modify yourself. The Question about the Splash, i found only the black logo on recalbox/system/resources/splash
        • wilson-jr
          Thank you very much. I'll try.
          • Nachtgarm
            Nachtgarm @abunille last edited by
            @abunille The correct location of themes to be used would be recalbox/share/system/.emulationstation/themes instead of recalbox/share_init/system/.emulationstation/themes. No root access needed and if an update comes along, you will keep your themes. 😉
