    How can I delete/hide emulator ?
    Your recalbox
    deletehide
    8
    10
    7319
    • drj59
      drj59 last edited by drj59
      Hi everyone !
      I need your help to find a way for hiding or deleting emulators from the main menu.
      I would like to have only the N64 emulator available.
      I found something in the Wiki but I don't know how to access the folder Share_Init
      I'm with the rev 8.1.1
      Thank's in advance
      nayok 1 Reply Last reply Reply Quote 0
      • nayok
        nayok @drj59 last edited by
        @drj59
        Hi
        https://forum.recalbox.com/topic/25259/hide-consoles/7
        look at the 7th comment from @Bkg2k
        Rpi 3 B+
        Recalbox 9.1
        Usb Storage
        USB Xin-Mo controller
        phsilva 1 Reply Last reply Reply Quote 0
        • phsilva
          phsilva @nayok last edited by
          @nayok
          hello, can you help me, I redid all the procedure mentioned and it doesn't add and all the tutorials I see on the net are from old versions can you help me to do this in 8 or contact me so I can send you the system link and you can edit to me?
          nayok 1 Reply Last reply Reply Quote -1
          • nayok
            nayok @phsilva last edited by nayok
            @phsilva you have 3 steps to achieve.
            • open recalbox.conf located in recalbox\share\system
            • scroll down to the end of the file and type this
            snes.ignore=1
            • save recalbox.conf
            this will hide snes from recalbox frontend.
            for all others systems, do the same.
            Rpi 3 B+
            Recalbox 9.1
            Usb Storage
            • phsilva
              @nayok
              It didn't work, I'm wanting to add a games folder in the system menu, here on the forum I found how to add it by editing the systemlist in the share/system/emulationstation folder, but still I'm not getting it
              Alvin 1 Reply Last reply Reply Quote -1
              • Alvin
                Alvin Banned @phsilva last edited by
                @phsilva
                I don't know that the problem is.
                In the old Versions of Recalbox a System only showed up if you put a Game-ROM in the corresponding Folder.
                For Example: If you put a Game-ROM in the NES Folder the NES shows up, if the Folder was empty the NES didn't show up
                So if you want to play N64 Games only and want only that the N64 shows up, leave all the other Folders empty.
                Than only the N64 and the "preinstalled Games" will show up, but there's a Way to hide these Games (just search the Board).
                • drj59
                  Thanks everyone, I found a way to hide all the default emulators, just to switch off an option on the main menu.
                  • Alvin
                    Alvin Banned @drj59 last edited by
                    @drj59 said in How can I delete/hide emulator ?:
                    Would be nice if you can tell us all here on this Board exactly where you found what !
                    • Mozzelex
                      Mozzelex last edited by
                      Main Menu
                      UI Settings
                      Game Filters
                      Hide Preinstalled Games
                      • petergray
                        petergray last edited by
                        Unfortunately, deleting emulators might be irreversible, so consider hiding instead. To hide unwanted emulators from your Recalbox 8.1.1 main menu, you can either remove their ROMs from the corresponding system folders within the "share" drive, or (if your Wiki mentioned it) edit the "menu.conf" file located in the "Share_Init" folder (accessible through File Explorer on your connected PC). Remember to refresh the game library after making changes. Hope this helps!
