    [PC] Installing on a HDD
    Your discoveries
    how-to pcrecalbox
    • SgtSlaughter
      SgtSlaughter last edited by
      Not sure if allowed but thought I'd share how a way to get Recallbox to install on a hard drive rather than booting from a flash drive each time if someone is running a dedicated PC for Recallbox
      1. Download BelenaEtcher and Recallbox image
        2.Format your HDD/SSD to ntfs, make sure it's allocated and hook it up to your main PC/Laptop.
        --I hooked mine into an empty m.2 slot I had but also works with SATA and USB enclosures. Its much faster if a process hooking straight onto your board.
      2. Open Belena and select you .iso/.tar
      3. Select your drive.
        --Belena registers HDD/SSD's as a system drive so you'll have to click the tab for system drives
      4. Confirm you want to flash to a system drive
      5. Voila now you have Recallbox on your hard drive.
      I have a dedicated business thin client that I'm using to run off of so there's no dual booting involved and now I have 1tb of disk space for games. Copy your roms through Samba, process is MUCH faster using the m.2 rather than straight onto the USB stick.
      100.6k
