    8BItDo SN30 PRO+ will not work after firmware update
    GamePad/GPIO/USB encoder
    8bitdo sn30 firmware update
    • erokx
      erokx last edited by
      In the past I had issues with 8BItDo SN30 PRO+ after Recalbox updates. I was able to fix:
      https://forum.recalbox.com/topic/23878/7-2-can-no-longer-pair-8bitdo-sn30-pro-controllers?_=1659532467052
      To summarize, I had to:
      1. downgrade firmware to v4.01
      2. reset to factory settings (may not have to)
      3. change driver from automatic to "system"
      4. choose B+Start (Android pairing mode)
      5. once paired, config controller
      6. Select the SN30 pro+ as controller 1 (and unplug the controller/keyboard used in pairing)
      WELL, I just stupidly upgraded the firmware to V5.04 thinking the issues had been fixed and now the controllers no longer work. So I tried to downgrade the firmware back to V4.01 but the Updater program only goes back to V5.02!!
      So now my controllers will not function at all and I have no way to downgrade the firmware that was the fix previously. Any ideas or other fixes? Searching the forum I have found no fix for this bug. HELP!
      • erokx
        OK, it took all morning but I have a solution. 8bitdo no longer has versions older than V5 of the firmware on their site. I was able to find an older version of the firmware here: https://github.com/fwupd/8bitdo-firmware/issues/36
        I downgraded to firmware to V4.02 and everything works again. Hope this helps someone else.
        Moral of the story, DO NOT upgrade your 8bitdo firmware if it is working!!!
          Scavy Global moderator @erokx last edited by
          @erokx hi
          i have the same pad, and same issue regarding the V5.04 firmware. I'll try to downgrade to see what's happening
