    Nintendo switch pro controller vs Recalbox 8.1
    Your recalbox
    nintendo switch recalbox 8.1
    • souzafl
      souzafl last edited by
      Friends, I updated recalbox to version 8.1 x64, but after restarting, my raspberry 4 stopped recognizing my nintendo switch pro controller via cable. Everything worked perfectly in version 8.0.2. Does anyone have a solution for this problem???
      • Aldébaran
        Aldébaran @souzafl last edited by Aldébaran
        Hi @souzafl, I just try and it works. Press L+R.
        souzafl 1 Reply Last reply Reply Quote 0
        • souzafl
          souzafl @Aldébaran last edited by
          @aldébaran Friend thank you so much for replying! Really the command works, but only when I hold the "L + R" before the boot screen, if you don't press the combination it is recognized as "Zhixu Gamepad". In version 8.0.2 the controller was recognized as Nintendo Switch after the entire update process was completed, and then pressing the "L + R" combination the controller assumed as Nintendo Switch.
          Could you tell me where I can change this process of recognizing/initiating the control, so that it accepts the combination "L + R", after the entire initialization process is completed?
          Aldébaran souzafl 2 Replies Last reply Reply Quote 0
          • Aldébaran
            @souzafl your Switch pro Controller is an official one, I mean a Nintendo one ?
            • souzafl
              souzafl @souzafl last edited by
              @souzafl said in Nintendo switch pro controller vs Recalbox 8.1:
              Friend found the solution: I analyzed the boot order in the boot.list file, and found differences between version 8.0.2 and 8.1. As I did a clean installation of version 8.1 on another card, I replaced this file from 8.0.2 in version 8.1, and with that I returned to the condition I needed: to recognize the control only after the entire system initialization process, and with the combination of the "L + R" buttons, it is possible to activate the control.
