    Rumble not working on Duckstation
    Emulator Arcade/PC/Console
    rumble duckstation
    • Jdock64
      Jdock64 last edited by
      Hi, I've been trying to fix this for days, and I'd really appreciate some help.
      I'm using and original ps1 dual analog controller (pic) with a usb adapter and it works just fine on duckstation, except for one issue, the rumble doesn't work, at all. I've set everything up so that it works, but it just won't vibrate.
      I have downloaded the drivers to make it vibrate, and it works perfectly from the controller options in windows control panel. I also tested it playing games on Epsxe, and it works, it vibrates perfectly, but in duckstation it does not work.
      Something that seems strange to me is that in ePSxe, to configure the vibration of the controller, there are several options, you can configure the vibration of the big and small motor. But in duckstation the only vibration configuration is to press any button on the controller to which you want to send the vibration.
      Could someone tell me if there is a solution to this? or if duckstation has rumble support for ps1 controllers at all? I'd appreciate your help. Thank you.
      Alvin 1 Reply Last reply Reply Quote -1
      • Alvin
        Alvin Banned @Jdock64 last edited by
        @jdock64
        Well, if I look here
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/duckstation
        under "Features" it seems that Duckstation doesn't support a Rumble-Funktion in Recalbox.
        If I look here
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/libretro-mednafen_psx
        here
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/libretro-mednafen_psx_hw
        and here
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/libretro-pcsx-rearmed
        it looks like these are the only Sony PSX-Emulators that are offering a Rumble-Funktion in Recalbox.
