    Only output device in audio is "Analog Output"
    pi3 audio
    1732
    • Dgamer
      Dgamer last edited by
      In sound settings, the only option is "Analog Output". Please help fix!
      • Fpan
        Fpan last edited by
        Same problem here
        on Raspberry pi4
        Everything was OK with Recalbox 7
        Thanks if you have a solution
        Alvin 1 Reply Last reply Reply Quote -1
        • Alvin
          Alvin Banned @Fpan last edited by
          @fpan
          1. On Pi4, did you use the right HDMI-Port (the one near the USB Power-Connection) ?
          2. Did you try another HDM-Cable ?
          3. Did you turn on your TV before the Raspberry ?
          4. Did you reset Recalbox to the "Factory Settings" ?
          Fpan 1 Reply Last reply Reply Quote 0
          • Fpan
            Fpan @Alvin last edited by
            @alvin
            1. seems a good hint
              Right HDMI port : no video
              Left HDMI port : no sound
            So may be I need to get video out of Right port
            I investigate but didn't find yet
            • Fpan
              Fpan @Fpan last edited by
              @Alvin
              2. No change with another cable
              3. no change
              4. no change...
              • Alvin
                @fpan
                Can you test it on another TV ?
                • Fpan
                  @alvin
                  not this week...
                  • Fpan
                    Fpan last edited by
                    @Alvin
                    but there must be some parameters : version 7 worked... (and kodi, and different Linux pi distribution...)
                    I'm sorry to have updated...
                    And can't find version 7 back...
                    Fpan 1 Reply Last reply Reply Quote -1
                    • Fpan
                      Woups I don't read enought the manual
                      If you're like me the answer is there :
                      https://wiki.recalbox.com/en/recalbox-8-0-faq#black-screen-issue
                      thanks Alvin, sorry for the time lost...
                      I go back to my final fantasy 7 game...
